SeeYou question
Old September 3rd 04, 06:43 AM
Ted Wagner
Default SeeYou question
Does anyone have any idea how SeeYou calculates the (ground) velocity at any
given fix in a flight?
I'm examining the take-off segment of one of my log files, and when I
calculate the velocity using the ubiquitous Great Circle algorithm from the
previous fix to the current fix, I get velocities that are *much* higher
than what SeeYou shows in the hover-hints as you trace the mouse along the
route.
Hack hack hack
~ted w/2NO
Old September 3rd 04, 07:10 AM
Ted Wagner
A specific example:
In the log file in question, my take-off roll begins at 1:24:15pm, when the
latitude/longitute fixes start to move.
Calculating the instantaneous speed as the distance from the previous fix to
the current fix divided by the time between those two fixes, I have these
speeds:
+15 seconds: 43mph
+20 seconds: 59mph
+25 seconds: 72mph
+30 seconds: 81mph
But loading the same file in SeeYou and looking at the data that pops up
next to the mouse pointer and checking the speeds at the same points:
+15 seconds: 13mph
+20 seconds: 22mph
+25 seconds: 33mph
+30 seconds: 43mph
Those are some rather drastic speed differences. The tow plane was one of
Turf's Pawnees, which in the warmest weather don't have me sitting at 35
knots a full 30 seconds into the take-off roll.
The distance algorithm I'm using is the classic Great Circle:
distance_in_miles = 3956.0775034473 * arccos( SIN(lat1) * SIN(lat2) +
COS(lat1)*COS(lat2) * COS(lng1-lng2) )
Any other hackers out there played with this stuff?
-tw
Old September 3rd 04, 08:40 AM
Jim Vincent
I recommend you post this directly on the Seeyou website...the help you get
there will be far more focused on your needs.
Jim Vincent
N483SZ
illspam
Old September 3rd 04, 10:49 AM
Andrej Kolar
Hi Ted,
SeeYou uses a filter, a sort of smoothing algorythm for the groundspeed
velocity calculations. Default value is 20s which means that 20 second.
You can control the smoothing through Tools Options Statistics
Groundspeed filter. Set it to "1s" to have "no filter".
Regards,
Andrej Kolar
glider pilots use
http://www.SeeYou.ws
On Thu, 2 Sep 2004 22:10:58 -0700, Ted Wagner
A specific example:
fix to
speeds:
+15 seconds: 43mph
+20 seconds: 59mph
+25 seconds: 72mph
+30 seconds: 81mph
+15 seconds: 13mph
+20 seconds: 22mph
+25 seconds: 33mph
+30 seconds: 43mph
-tw
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
SeeYou MOBILE v2.0! Roy McMaster Soaring 10 July 12th 04 01:25 AM
Commercial - StrePla Competitive Upgrade Paul Remde Soaring 20 June 1st 04 08:48 PM
SeeYou Mobile question Greg Arnold Soaring 1 February 19th 04 05:24 PM
Virtual exploration with SeeYou John Galloway Soaring 3 February 19th 04 11:49 AM
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 01:14 AM
