ballasting with integral tanks
Old September 20th 04, 02:43 PM
Flavio Formosa
Default ballasting with integral tanks
I remember having once seen on 'Soaring' an article
about a clever (albeit complicate) ballasting system
designed for an LS6, where water came from the mains
supply, but with a vertical spill pipe of a precise
length inserted between the supply and the glider,
to avoid exceedingly high pressure and wing shell bursting.
Anyone using this system for integral tanks with bottom
filling (LS8 style)? What's the advisable spill pipe
height for a quick but safe fill?
Thanks in advance,
cheers
Flavio
Old September 21st 04, 04:18 AM
Larry Goddard
The ones that I have seen use a clear plastic tube made for safety
covers for fluorescent lighting tubes. They are approximately 1.7
inches in diameter and 4 feet long. Light weight and completely clear.
Keep in mind also that the height specification that Todd mentions is
height above the wing.
Larry Goddard
"Zero One"
USA
Spill pipe height is determined by the maximum pressure your
wing can withstand. It's usually specified in your manual.
Mine says one meter. It is important, if using a high
pressure source, to absolutely prevent the pressure from
exceeding the maximum value. I've heard the awful crack of
a splitting wing when it gets too high.
If your high pressure source can produce a relatively high
flow rate, you will want a large diameter spill pipe. A
transparent one would be nice to monitor pressure as you
fill.
The spill pipe is often created with a simple T-fitting.
It's a good idea to orient the T so the pressure comes in
the bottom on one side of the straight through leg of the T,
the spill pipe is vertically straight through on the other
side of the straight through leg and the feed for your wing
tank is from the ninety degree leg of the T.
I've also considered buying one of those pressure reducers
sold for motorhomes to keep their internal plastic plumbing
from bursting. They keep pressure below 40 psi, which is
still way too high, but perhaps they could be modified by
changing a spring. I'd still use the spill pipe, but I'd
worry less.
Todd Pattist - "WH" Ventus C
(Remove DONTSPAMME from address to email reply.)
Old September 21st 04, 07:50 AM
Clint
Flavio Formosa wrote in message ...
Thanks in advance,
cheers
Flavio
We have a system of this type built into our hanger. There is a 2m
high breather pipe between the tap and outlet. You plug the garden
hose directly into the glider from the system and open the tap until
you see the water rise up in the breather pipe (which is transparent).
You can't over-stress the wings as the water will overflow from the
breather pipe when the pressure exceeds 0.2 bar (2m head - you can
adjust the height of the top of the breather pipe to lower the maximum
pressure). I measured a flow rate of 6.7 litre/minute when filling my
LAK's tanks - thus it takes 30 minutes to fill the 200 litre tanks.
Clinton
LAK 12
Old September 21st 04, 06:07 PM
Bela
Based on Neil Green, my friend and fellow LS8 owner's work with brass
tubing, I built one from 3/4" PVC tubes. It is portable and comes
apart with a quick disconnect to fit into the back of a well loaded
SUV.
Mounted on a 16" square plywood platform is a vertical, about 1.5
meter tall PVC tube, with a faucet controlled, standard hose (T)
connection near the bottom. Above the hose intake is the another T
connection dimensioned such that the Rolladen supplied clear tubing
can be connected. The hight of this T connection is about the same as
the hight of the wing. The vertical PVC tube extends a little over
one meter above the wing through a quick disconnect for ease of
transport.
It's a two handed operation, one hand holds the Rolladen provided hose
to the wing water opening, the other controls water flow via the
faucet. For proper pressure there should be no water coming out at
the top of the PVC tube a little over one meter above the wing. Of
course I must pull the bird to a location where a water hose is
available.
All parts were purchased at a Home Depot with the help of a friendly
sales person, had the Rolladen tube with me to find the correct size
for the T connection for the outlet.
I could take a photo of it if my description is not enough.
Bela
Old September 21st 04, 11:17 PM
VentusDriver
Clinton
LAK 12
Be very careful with these devices, they work great, if built
correctly, but they can do alot of damage if improperly designed.
Things to think about,
1. The height of the "breather tube" ( called a stand pipe in
engineering parlance) is very important, the 2 meter tube referenced
above will allow the wing to experiance a pressure of ~ 3 PSI if the
base of the tube is at the same level as the wing. 3psi may very well
damage or destroy the wing, it is nearly a quarter of a ton of force
per square foot. I would not allow the tube to be more than about .5
meters above the wing if it were mine.
2. The diameter of the Standpipe must be several times the diameter
of the input hose from the mains, because it has the job of
discharging any flow greater than allowable. Bigger in this case is
safer.
Jim (GB)
F-104 in Viet Nam Question Don Harstad Military Aviation 2 August 28th 04 09:40 AM
Night bombers interception in Western Europe in 1944 Bernardz Military Aviation 205 July 22nd 04 06:31 PM
#1 Jet of World War II Christopher Military Aviation 203 September 1st 03 04:04 AM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 10:14 AM
Tanks for nothing (repost from Bearhawk list) Del Rawlins Home Built 0 August 6th 03 04:06 AM
