Cessna 195
Old May 2nd 18, 02:39 PM posted to alt.binaries.pictures.aviation
Miloch
Default Cessna 195
https://en.wikipedia.org/wiki/Cessna_195
The Cessna 190 and 195 Businessliner are a family of light single radial engine
powered, conventional landing gear equipped, general aviation aircraft which
were manufactured by Cessna between 1947 and 1954.
The 195 model was also used by the United States Air Force, United States Army,
and Army National Guard as a light transport and utility aircraft under the
designations LC-126/U-20.
The Cessna 190 and 195 were Cessna's only postwar radial-engined aircraft. The
first prototype flew in 1945, after the end of World War II and both the 190 and
195 entered production in 1947.
The 195 was the first Cessna airplane to be completely constructed of aluminum
and features a cantilever wing, similar to the pre-war Cessna 165 from which it
is derived. The wing differs from later Cessna light aircraft in that it has a
straight taper from root chord to tip chord and no dihedral. The airfoil
employed is a NACA 2412, the same as used on the later Cessna 150, 172 and 182.
The 190/195 fuselage is large in comparison to other Cessna models because the
42" diameter radial engine had to be accommodated in the nose. There are two
rows of seats: two individual seats in the first row, with a comfortable space
between them and up to three passengers can be accommodated on a bench seat in
the second row.
The 190/195 has flat sprung-steel landing gear legs derived from Cessna's
purchase of the rights to Steve Wittman's Big X. Many have been equipped with
swiveling crosswind landing gear which allows landing with up to 15 degrees of
crab. While the crosswind gear simplifies the actual landing, it makes the
aircraft difficult to handle on the ground. The 195 is equipped with a
retractable step that extends when the cabin door is opened, although some have
been modified to make the step a fixed unit.
The aircraft was expensive to purchase and operate for private use and Cessna
therefore marketed them as mainly as a business aircraft under the name
"Businessliner".
The engines fitted to the 190 and 195 became well known for their oil
consumption. The aircraft has a 5-US-gallon (19 L) oil tank, with 2 US gallons
(7.6 L) the minimum for flight. Typical oil consumption with steel cylinder
barrels is 2 US quarts (1.9 L) per hour.
A factory-produced floatplane version was equipped with a triple tail for
improved yaw stability. The tail resembles that of the Lockheed Constellation.
The Cessna 195 produces a cruise true airspeed of 148 knots (274 km/h) (170 MPH)
on a fuel consumption of 16 US gallons (61 L) per hour. It can accommodate five
people.
Including the LC-126s, a total of 1180 190s and 195s were built.
Role
Light personal and business aircraft
National origin
United States
Manufacturer
Cessna Aircraft Company
First flight
1945
Introduction
1947
Primary users
United States Army
Produced
1947-1954
Number built
1,180
Unit cost
USD$12,750 (1947)
Developed from
Cessna 165
The Cessna 190 and 195 are considered "one of the finest classics ever built" by
pilots and collectors and are much sought after on the used aircraft market.
Brazilian-registered Cessna 195 at Marte airfield, Sao Paulo in 1975
On July 24, 2017 the number of 190s and 195s still registered in the USA we
86 Cessna 190
225 Cessna 195
125 Cessna 195A
126 Cessna 195B
In February 2014 there were three Cessna 190s, eleven Cessna 195s, two Cessna
195As and two Cessna 195Bs registered in Canada. Other Cessna 190 and 195
aircraft have been purchased by private pilot owners resident in Brazil and the
United Kingdom.
Specifications (Cessna 195)
General characteristics
Crew: one
Capacity: four passengers
Length: 27 ft 4 in (8.33 m)
Wingspan: 36 ft 2 in (11.02 m)
Height: 7 ft 2 in (2.18 m)
Empty weight: 2,100 lb (953 kg)
Gross weight: 3,350 lb (1,520 kg)
Fuel capacity: 75 US gallons (280 l; 62 imp gal)
Powerplant: 1 × Jacobs R-755 radial engine, 300 hp (220 kW)
Propellers: 2-bladed Hamilton Standard constant speed propeller
Performance
Maximum speed: 178 mph (286 km/h; 155 kn)
Cruise speed: 170 mph (274 km/h; 148 kn) at 70% power
Stall speed: 62 mph (100 km/h; 54 kn) power off, flaps 45°
Never exceed speed: 200 mph (322 km/h; 174 kn)
Range: 800 mi (695 nmi; 1,287 km) at 70% power
Service ceiling: 18,300 ft (5,600 m)
Rate of climb: 1,200 ft/min (6.1 m/s)
Wing loading: 15.36 lb/sq ft (75.0 kg/m2)
Old May 2nd 18, 08:12 PM posted to alt.binaries.pictures.aviation
Mitchell Holman[_9_]
Default Cessna 195
Miloch wrote in
news
radial engine powered, conventional landing gear equipped, general
aviation aircraft which were manufactured by Cessna between 1947 and
1954.
States Army, and Army National Guard as a light transport and utility
aircraft under the designations LC-126/U-20.
aircraft. The first prototype flew in 1945, after the end of World War
II and both the 190 and 195 entered production in 1947.
aluminum and features a cantilever wing, similar to the pre-war Cessna
165 from which it is derived. The wing differs from later Cessna light
aircraft in that it has a straight taper from root chord to tip chord
and no dihedral. The airfoil employed is a NACA 2412, the same as used
because the 42" diameter radial engine had to be accommodated in the
nose. There are two rows of seats: two individual seats in the first
row, with a comfortable space between them and up to three passengers
can be accommodated on a bench seat in the second row.
Cessna's purchase of the rights to Steve Wittman's Big X. Many have
been equipped with swiveling crosswind landing gear which allows
landing with up to 15 degrees of crab. While the crosswind gear
simplifies the actual landing, it makes the aircraft difficult to
handle on the ground. The 195 is equipped with a retractable step that
extends when the cabin door is opened, although some have been
Cessna therefore marketed them as mainly as a business aircraft under
the name "Businessliner".
gallons (7.6 L) the minimum for flight. Typical oil consumption with
steel cylinder barrels is 2 US quarts (1.9 L) per hour.
for improved yaw stability. The tail resembles that of the Lockheed
Constellation.
(170 MPH) on a fuel consumption of 16 US gallons (61 L) per hour. It
can accommodate five people.
Role
National origin
United States
Manufacturer
First flight
1945
Introduction
1947
Primary users
United States Army
Produced
1947-1954
Number built
1,180
Unit cost
USD$12,750 (1947)
Developed from
Cessna 165
built" by pilots and collectors and are much sought after on the used
aircraft market.
USA we
86 Cessna 190
225 Cessna 195
125 Cessna 195A
126 Cessna 195B
Cessna 195As and two Cessna 195Bs registered in Canada. Other Cessna
190 and 195 aircraft have been purchased by private pilot owners
resident in Brazil and the United Kingdom.
Crew: one
Performance
One of my favoritss, thanks. I have
flown Beavers but never the 195, but
always wanted to.
Old May 2nd 18, 08:59 PM posted to alt.binaries.pictures.aviation
Miloch
Default Cessna 195
In article , Mitchell Holman
says...
Miloch wrote in
news
1954.
always wanted to.
In the VNam war, my aviation company had both UH-1s and Beavers. Flew down to
Ca Mau (tip of the delta in a U-6 and we left at midnight...as the junior
officer (1st lieutenant & only rated for helicopters) the pilot (a captain) had
me take the controls and do the flying back to Saigon while he dozed. As there
was no electricity in those days in the small villages, it was pitch black with
no horizon and the only lights to focus on were the city lights of Saigon...way
off in the distance.
Flew it on instruments most of the way back. I remember them as no
frills-simple and noisy!!
Cessna 150 pics 2 [02/11] - Cessna 150s produced before 1964, such as this 1962 Cessna 150B.jpg (1/1) Miloch Aviation Photos 0 February 25th 18 01:45 PM
Cessna 150 pics [2/8] - 1967 model Cessna 150G instrument panel.jpg (1/1) Miloch Aviation Photos 0 February 25th 18 01:43 PM
Cessna AT-17 Bobcat pics 2 [5/8] - DSC_1928 Cessna T-50 UC-78 N59188 left front taxiing l.jpg (1/1) Miloch Aviation Photos 0 January 9th 18 03:42 PM
Cessna 210 pics [04/12] - A Cessna T210L shows the later models' strutless cantilever wing.jpg (1/1) Miloch Aviation Photos 0 December 26th 17 03:42 PM
Cessna 210 pics [03/12] - A Cessna P210N Pressurized Centurion with its distinctive small windows.jpg (1/1) Miloch Aviation Photos 0 December 26th 17 03:42 PM
