LSA weight limit increase, good for gliding?
Old December 21st 18, 03:36 AM posted to rec.aviation.soaring
Default LSA weight limit increase, good for gliding?
It appears that the FAA might be upping the weight limit on LSA aircraft. One of the main limits holding back marketable gliders from being LSA eligible was the low Vne. If they are opening up the LSA rules for more change, and changing to more of a risk-based rulemaking we should be able to argue that Certified gliders have high Vne limits, and the risk is low.
Is there anything the gliding community wants to get done if new rules are posted in January 2019?
reference:
"high-ranking FAA source has confirmed that the FAA plans to almost triple the maximum weight for most light sport aircraft to 3600 pounds in rulemaking that will be introduced in January. The source confirmed the scant details of a Facebook post written by AOPA Senior VP of Media and Outreach Tom Haines from the AOPA Regional Fly-In at Carbondale, Illinois. “Great news out of AOPA: your freedom to fly Fly-in at Carbondale,” Haines wrote. “In January the FAA will issue a notice of proposed rulemaking increasing max weight for a light sport airplane from 1320 lbs to 3600 lbs."
https://www.avweb.com/avwebflash/new...-231639-1.html
Chris
Light weight low cost four stroke engines, good Rotax replacements. Bushleague Piloting 1 October 13th 05 05:49 AM
Light weight low cost four stroke engines, good Rotax replacements. Jim Carriere Naval Aviation 0 July 8th 05 03:31 AM
Light weight low cost four stroke engines, good Rotax replacements. [email protected] Home Built 15 July 3rd 05 06:31 PM
pilot weight and gliding John Lee Soaring 4 August 31st 03 07:53 PM
Pilot weight and gliding JohnH Soaring 26 August 28th 03 12:08 AM
