Switching between multiple Volksloggers
Old September 28th 04, 09:07 PM
Mark Zivley
Default Switching between multiple Volksloggers
Should work, best to test it first. Also, check to see if there is a
"ground" in the serial wiring diagram too. If so, you need to connect
them together as well, but that can be done permanently (not switched) I
would think.
Todd Pattist wrote:
A friend has two Volksloggers, primary and secondary. The
primary feeds data to his SN-10. The primary failed last
weekend and he wants a way to switch the secondary to the
SN-10 while in flight if it happens again.
I suggested a simple double pole double throw switch to
switch the TXD and RXD lines from the SN-10 between the
primary and secondary VL's. Has anyone done this? Any
problems?
Thanks.
Todd Pattist - "WH" Ventus C
(Remove DONTSPAMME from address to email reply.)
Old September 28th 04, 09:17 PM
tango4
I do the same with my twin colibris. Just switch the tx and RX lines. No
Problem
Ian
"Todd Pattist" wrote in message
problems?
Thanks.
Old September 28th 04, 09:25 PM
Jim Vincent
Diving into this perhaps a little late, but I wonder the value of doing this.
Is the SN-10 that much more reliable than a Volkslogger, your battery, or the
wiring switches? If you're found any of these individual components to
repeatedly fail, then I advocate replacing the component.
Looking at just two of the devices that contribute to the FMEA (Failure Modes
and Effects Analysis), let's assume the SN-10 and Volkslogger are equally
reliable. By only having one redundant, you're reduced the chance of failure
in half. BUT, assuming both are very reliable, on the order of 10,000 between
hours (reasonable), you'll increase the reliability from 99.999998 % to
99.999999 %.
Lastly, the switch that you need to switch between the two Volksloggers has its
own reliablity issue. That in inself may make the whole darn thing less
reliable.
I think the KISS approach is the best...one of each gizmos.
Batteries are a different story though. I have a spare one purely to power the
datalogger if the main one dies.
Jim Vincent
N483SZ
illspam
Old September 29th 04, 12:06 AM
Paul Remde
Hi,
Several years ago a used a double pole-double throw switch to select between
my GPS-NAV and Garmin 90 for input to my L-NAV. That way I gained access to
the large Jepessen database when I was a long way from home. It worked
great.
However, the downside to using a switch is that RS-232 data lines are noisy
and it would be difficult to shield the switch well (putting foil around it
wont help). It may cause radio interference. Therefore, I don't really
recommend it.
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"tango4" wrote in message
Problem
Ian
problems?
Thanks.
Old September 29th 04, 03:47 PM
tango4
To do the job properley the swich should be mounted in a metal box ( sheet
ali or diecast ) and the box should be grounded. But I assumed that you'd do
it that way anyway!
Ian
noisy
it
recommend it.
Thanks Paul, that's the kind of info I was looking for.
What kind of problems did you see? Were there problems on
the RS-232 lines that caused data communication errors or
are you referring to RFI and radio noise? I was going to
give him some shielded cable for running to/from the switch,
but I hoped it wasn't going to require putting the switch in
a shielded box. I've got two GPS units that plug into
sockets where the RS-232 RXD/TXD lines are exposed for a few
inches, and I'm not seeing any problems. He was considering
mounting one Volkslogger on its side so he could remove the
cable and swap them, but I think that would cause more
problems (with reception) than a simple switch.
Old September 29th 04, 04:44 PM
Paul Remde
Hi Todd,
It worked fine but I could hear it on the radio. Puting the switch in a
metal box and grounding the box should help but it seems silly to me since
the Volkslogger and SN-10 both can log the flight and are both very
reliable. Of course the SN-10 log can't be used for badges or records but
it could probably be used as a backup if the Volkslogger failed (which is
not likely if reliable 12V power is assured).
Paul Remde
noisy
it
recommend it.
FS 2004 with multiple monitors - how to save settings? Horst Walter Simulators 5 December 8th 04 02:29 PM
Airmen at Osan switching from M16A2 to lighter M4 carbine, By Franklin Fisher, Stars and Stripes Otis Willie Military Aviation 0 April 29th 04 05:07 AM
Switching to ground.... David Rind Piloting 85 April 16th 04 07:53 PM
Where is approach good about multiple approaches and clearances in the air? Andrew Gideon Instrument Flight Rules 29 February 14th 04 03:51 AM
FS 2002 Multiple Monitors Hugh Roberton Simulators 1 September 22nd 03 02:49 PM
