Opinions on ASW-17
Old October 7th 04, 10:10 PM
Thomas Mærsk Pedersen
Default Opinions on ASW-17
I am considering buying an AWS-17 - any opinions on this glider with regards
to performance, handling, value for money etc?
Comments will be greatly appreciated.
Regards,
Thomas Mærsk
Copenhagen, Denmark.
Old October 8th 04, 04:09 AM
goneill
performance, handling, value for money "buy it now"
The 17 scores massive on these points
BUT they have these reality checks
1/ Typical early open class ,heavy "MUST" have rigging gear
2/ they have a narrow approach angle ,weak airbrakes so best
countryside to fly them over is where outlanding fields are larger
than usual ,they land just as short as a 15meter ship but pilot
workload is much more intense.Very little room for error.
"Thomas Mærsk Pedersen" wrote in message
regards
Regards,
Thomas Mærsk
Old October 8th 04, 06:19 AM
Gary Boggs
I have a friend that has one and it is a bitch to put together. Good
performance for the dollar though.
Boggs
regards
Regards,
Thomas Mærsk
Old October 8th 04, 10:32 AM
Jean
As a happy owner - F-FAQC - I would just add that it's not very "nervous" as
roll rate is not impressive (in mountain flight some anticipation is needed)
however the controls remains light. Climbing ability is outstanding, and
it's very good in transition up to 160 km/h.
My co-owner succeeded a 1000km flight last summer from Challes-les-Eaux
(France/North Alps).
Mine has a tail chute which is very efficient at compensating the weak
airbrakes; However tail chutes are not 100% reliable so it's better to keep
trained to narrow approach angle.
.... And yes a rigging gear is mandatory if you want to keep friends
Jean
"goneill" a écrit dans le message de
regards
Regards,
Thomas Mærsk
Old October 9th 04, 02:03 AM
W.J. \(Bill\) Dean \(U.K.\).
It is possible to modify the brakes by fitting a second paddle to each of
the four brakes (top and bottom).
This is the same mod. as that to the ASW19.
I know of several examples which have had this modification, and I have
flown
one of them. I have heard the modified braking described as similar to the
K21, I agree.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"goneill" wrote in message
performance, handling, value for money "buy it now".
The 17 scores massive on these points.
BUT they have these reality checks:
1/ Typical early open class, heavy "MUST" have rigging gear.
2/ They have a narrow approach angle, weak airbrakes so best
than usual, they land just as short as a 15meter ship but pilot
workload is much more intense. Very little room for error.
regards to performance, handling, value for money etc?
Regards,
Thomas Mærsk
Old October 9th 04, 02:35 AM
Eric Greenwell
=20
Boggs
=20
"Thomas M=E6rsk Pedersen" wrote in message
=20
=20
regards
=20
Be sure the wing inspections have been done - I think there is some wood =
inside that can cause problems.
--=20
Eric Greenwell
Washington State
USA
Old October 9th 04, 05:18 AM
ken ward
Save yourself some money. Buy a used LAK-12 with same performance. The
LAK looks like a 17 clone, and will have way less hours. Everyone
whinges about the 220# weight of a complete 12 wing, but the inner 17
panel by itself weighs 190#. you'll need some helpers.
Ken
no, my 12 is NOT for sale!
Jean
regards
Regards,
Thomas Mærsk
Old October 9th 04, 08:16 AM
Janusz Kesik
U=BFytkownik ken ward w wiadomo=B6ci do grup =
dyskusyjnych =
m...
Save yourself some money. Buy a used LAK-12 with same performance. =
The=20
LAK looks like a 17 clone, and will have way less hours. Everyone=20
whinges about the 220# weight of a complete 12 wing, but the inner 17=20
I fully agree, save your money for other things, the LAK-12 looks like =
xerox of the '17' and our local owner is happy with his '12' he brought =
from Russia. It had only 104h logged then.
Regards,
--=20
Janusz Kesik
http://www.wroclaw.dolny.slask.pl
See Breslau (Wroclaw) in photography
From the XIX Century, through the 1945 Festung Breslau, to the photos =
taken today morning...
Old October 11th 04, 07:29 PM
Jean
Well, according to Schleicher GmbH "for the ASW 17 there is no approved
technical note/drawing or modification
kit for double airbrake paddles available"
Jean
"W.J. (Bill) Dean (U.K.)." a écrit dans le message
de ...
flown
K21, I agree.
Regards,
Thomas Mærsk
Old October 14th 04, 01:55 PM
I do not have the drawings etc. with me, they are with the repairer who did
the modification. The drawings etc. are the same as the ones for the
ASW19. I got them from the BGA who have of course approved the
modification.
Remember that the ASW19 modification was not in origin by Schleicher; it was
private and then Schleicher adopted it and included it in new production.
Perhaps there are advantages in flying in the U.K. rather than in France!
When I had a tail wheel fitted to the ASW17 to replace the tailskid, the
repairer used a deep moulding for the wheel with a fixed ballast point
inside at the top. Ballast can be fitted or removed just by taking out the
wheel to get access to the ballast point bolt. This modification can be
fitted to the ASW19 and 20.
There is also a U.K. approved modification to the ASW20 to fit a tail
ballast tank, it is also approved to double the brake paddles on the ASW20.
"Jean" wrote in message
technical note/drawing or modification kit for double airbrake paddles
available".
Jean
message de ...
of the four brakes (top and bottom).
flown one of them. I have heard the modified braking described as
similar to the K21, I agree.
Opinions on Cessna 340, 414 and 421 john szpara Owning 55 April 2nd 04 10:08 PM
Opinions wanted ArtKramr Military Aviation 65 January 21st 04 05:15 AM
OPINIONS: THE SOLUTION ArtKramr Military Aviation 4 January 7th 04 11:43 PM
Rallye/Koliber AD's and opinions R. Wubben Owning 2 October 16th 03 06:39 AM
Rallye/Koliber AD's and opinions R. Wubben Piloting 2 October 16th 03 06:39 AM
