Inreach Mini
Old February 6th 19, 01:31 PM posted to rec.aviation.soaring
Tango Eight
Default Inreach Mini
Has anyone found anything not to like about the Inreach Mini?
T8
Old February 6th 19, 01:39 PM posted to rec.aviation.soaring
Hi Everyone,
How do you use the mini? Does battery life allow for tracking during flight or is it a single text upon landing kind of thing?
Old February 6th 19, 04:40 PM posted to rec.aviation.soaring
Dan Marotta
Paying a subscription for something I wouldn't use except in an
emergency is high on my list.
None of my other emergency gear requires me to pay for the privilege of
having it sit in a bag.Â* I can be tracked via my transponder, ADS-B, my
phone if I have location services turned on, and probably my Flarm to a
lesser degree and I don't need to send text messages via satellite while
in flight.Â* Oh yeah...Â* I've got an old flip phone that will dial 911 if
there's a cell tower within range.Â* No charge!
And before starting off on how glider pilots are cheap, I like to think
that some glider pilots simply choose to spend their money on other goodies.
T8
Dan, 5J
Old February 6th 19, 05:08 PM posted to rec.aviation.soaring
Tango Eight
Inreach is useful in non-emergency situations when working phones are scarce. I used to arrange one retrieve last Summer, worked great. Service is $20 a month, $2 a month when suspended, in case this clears up any misconceptions about that.
Anyhow, I didn't mean this to be a thread about inreach service or inreach vs anything else. I am specifically interested in glider pilot experience with the Inreach Mini Device, which was new about last May or June.
best,
Evan / T8
T8
Dan, 5J
Old February 6th 19, 07:23 PM posted to rec.aviation.soaring
Dan Marotta
I used on older inreach a couple of years ago when flying in a friend's
ASH-30mi.Â* At the time it was rather clumsy and error prone to use.Â*
Hopefully that has been cleared up.
The service charges you mentioned do, indeed, sound more reasonable than
I had imagined (my bad) and my wife does want to look into one before we
head out on our flying trip to Alaska.Â* Thanks for the info!
best,
Evan / T8
T8
Dan, 5J
Dan, 5J
Old February 6th 19, 07:29 PM posted to rec.aviation.soaring
Dan Daly[_2_]
***some deleted***
@T8 - perhaps in the U.S.; here in Canada it's $44.95 plus 13% tax/month for the plan that can be suspended ($34.95/mo annual with no suspension). We have great OGN coverage that will give the Rescue Coordination Centre a good starting point. To me, not worth it here - but at half the price, maybe.
Cheers
Old February 6th 19, 07:56 PM posted to rec.aviation.soaring
Tango Eight
***some deleted***
@T8 - perhaps in the U.S.; here in Canada it's $44.95 plus 13% tax/month for the plan that can be suspended ($34.95/mo annual with no suspension). We have great OGN coverage that will give the Rescue Coordination Centre a good starting point. To me, not worth it here - but at half the price, maybe..
Cheers
Check out the "safety" plan.
-T8
Old February 6th 19, 10:45 PM posted to rec.aviation.soaring
Dan Marotta
I was actually looking at inReach until I found the following in the
small print:
Minimum cost is $49.90 on the inReachâ„¢ Safety Plan, $64.90 on the
inReachâ„¢ Recreation Plan, $89.90 on the inReachâ„¢ Expedition Plan and
$119.90 on the inReachâ„¢ Adventurer Plan.
Ii appears that if you just leave the thing in a bag for emergency use,
you'll pay $29.95 to activate the unit, $0.30/track point if you use it
for tracking, $0.85/message if you send (or I would guess) receive a
text, and, if you don't use it enough to get up to $49.90/month, that's
what you'll pay as a minimum.Â* Then there's the acquisition cost...
That rivals DirecTV in cost and I dumped them.
***some deleted***
Cheers
-T8
Dan, 5J
Old February 6th 19, 11:44 PM posted to rec.aviation.soaring
JS[_5_]
T8
If it connects to a phone like the other InReach devices the mini should be fine. Personally don't find the InReach SE cumbersome, or expensive for that matter.
Suggest downloading the Garmin Earthmate app and the Text To Speak engine for the phone you'll connect, so you can use speech to text in the middle of nowhere. Test it at home in airplane mode.
OGN is great, but the N part needs to be much larger to be functional. Opening the OGN app and panning around N America, found only three stations in New Mexico and one between Montreal and Ottawa. Is that the extent of the N. American network?
I also use amateur radio APRS tracking. That network is huge compared to OGN, but still has blanks.
New inReach Device - Mini [email protected] Soaring 5 May 7th 18 07:18 AM
New - Garmin inReach Mini - Available June 15, 2018 Paul Remde Soaring 0 May 4th 18 05:48 AM
Inreach Tango Eight Soaring 4 May 2nd 18 03:26 PM
InReach died Dan[_6_] Soaring 6 February 25th 17 01:19 AM
Inreach best way to mount? joesimmers[_2_] Soaring 7 April 5th 14 04:34 PM
