Fixing longitudinal crack in wood canopy rail
Old April 10th 19, 02:13 AM posted to rec.aviation.soaring
George Haeh
Default Fixing longitudinal crack in wood canopy rail
The new canopy retention bungee may have slipped through the eye hook or the knot failed. Fortunately the canopy was not broken, but the hinges had to be replaced.
Then we found a longitudinal crack. As a long time woodworker, my inclination is to inject Weldbond and clamp. Weldbond seems to do well keeping tail skids attached to fiberglass gliders.
Perhaps not acceptable for spars, but much less loading on a canopy rail which is secured at four points.
Old April 10th 19, 03:12 PM posted to rec.aviation.soaring
Not familiar with Weldbond. I expect what I would do us use epoxy. Spread crack a bit if possible. Warm the work and epoxy to reduce viscosity and help to maximize wicking and penetration. Then clamp and keep a bit warm while it cures.
UH
Crack canopy at the sliding glass screw hole. Tim Murphy[_2_] Soaring 14 October 15th 13 06:21 PM
[USA] FAA approved canopy crack repairs Jim Britton Soaring 5 October 18th 10 03:33 PM
Canopy crack :( lanebush Soaring 6 June 8th 10 07:44 AM
Do you need a canopy vent rail? qfly Soaring 0 December 27th 05 05:23 AM
Canopy crack repair Pete Brown Soaring 0 May 18th 04 04:09 AM
