Cambridge Fuse Question
Old January 3rd 05, 06:11 AM
Brian Iten
Default Cambridge Fuse Question
I am in the process of renewing my instrument panel
and want to install a fuse or breaker on the panel
for my 302 and model 20. I have looked in the appropriate
manuals for the proper fuse size but can not find anything.
Can anyone help me with this?
Thanks
Brian
MB1
Old January 3rd 05, 03:18 PM
cernauta
Hi,
1 Amp is usually fine, and easily available.
Aldo Cernezzi
Old January 3rd 05, 06:51 PM
Greg Arnold
Hi,
Aldo Cernezzi
The 302 manual says the instrument uses 900 mA when hooked to an Ipaq
with backlight on, so a 1 amp fuse might be a bit small.
Old January 3rd 05, 10:50 PM
Paul Remde
Hi,
Make sure it is a "Slow Blow" fuse.
1 A for the GPS-NAV and 2 A for the 302 would be a good start.
Paul Remde
"Greg Arnold" wrote in message
newsFfCd.38262$8e5.14139@fed1read07...
Hi,
Aldo Cernezzi
The 302 manual says the instrument uses 900 mA when hooked to an Ipaq with
Old January 3rd 05, 10:53 PM
Greg Arnold
Why "slow blow"? I am pretty sure my gliders always came with "fast
blow" fuses.
Paul Remde wrote:
Hi,
Paul Remde
Hi,
Aldo Cernezzi
Old January 3rd 05, 11:05 PM
Paul Remde
Hi Greg,
I can't say I'm an expert on fuses. I use slow blow fuses because they will
blow plenty fast if there is a short circuit and they allow for a short
period of higher current flow. That is nice because the GPS-NAV and 302
have internal capacitors (I believe) to help ride through very short power
losses such as when switching between 2 glider batteries (a very nice
feature not found in many soaring instruments). The capacitors cause the
units to have a slightly high inrush current when power is first applied.
That is my 2 cents. Can anyone express agreement or concern with my
suggestion?
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
news:WbjCd.38296$8e5.30997@fed1read07...
Why "slow blow"? I am pretty sure my gliders always came with "fast blow"
fuses.
Paul Remde wrote:
Hi,
Paul Remde
Hi,
Aldo Cernezzi
Old January 3rd 05, 11:36 PM
Don Hammer
Seem to remember from A&P school that a fuse is there to protect the
wire and not the component. If you know the current draw of the
component, AC43.13-2 will help you with wire size needed and the
recommended fuse size for that wire. On the same note, your
instructions probably call for a particular wire size. Use the fuse
recommended for that size wire.
I'm on the road, or I'd look it up for you. Anyone else have a copy
of the AC?
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old January 4th 05, 02:24 AM
Tony Verhulst
this is certainly true in an automobile because the cost of replacing
the wiring may be much more than the cost of replacing the component. In
sailplanes, the wiring is trivial to replace and I choose to protect the
expensive component instead.
Tony V.
Old January 4th 05, 07:39 AM
Eric Greenwell
When you protect the wiring, you are protecting the "expensive
component" - the glider! A wire fire is always exciting, as the smoke
creeps out around the edges of the panel... But practically speaking, a
fuse that protects the 302 will also protect the wiring, unless you are
using _much_ smaller wire than normal. I vaguely recall that the 302 has
an internal self-resetting fuse - a call to Gary K at Cambridge would
discover the truth.
Eric Greenwell
Washington State
USA
Old January 4th 05, 03:43 PM
m pautz
blow" fuses.
Paul Remde wrote:
Hi,
Paul Remde
Hi,
Aldo Cernezzi
Slow blow is usually used for motors, where the initial current flow
greatly exceeds normal operation. For electronics, the general rule is
a fast blow fuse. All electronic equipment have capacitors in the power
supply that cause a greater inrush. I am not sure if the extra size
of the capacitors of the 302 would cause an inrush current excessive
enought to warrent the need of the slow blow. Maybe someone else can
provide some emperical test results. The general rule for the size of a
fuse is twice the normal current flow.
The purpose of a fuse is to keep the wire from burning if there is a
short. A fuse doesn't do a whole lot for protecting the equipment. If
there is an internal short in the equipment, the damage to the equipment
has already been done. The equipment fuse simply protects the internal
wiring, or circuitry that leads the the failed component.
That is why wiring fuses, or breaker panels are at the power source.
There should be a fuse right at the battery. The fuse wouldn't help if
the battery is behind the seat, and the first fuse is behind the panel.
With that arrangement, a frayed wire at the panel would create a fire
between the battery and the panel. This main fuse, located at the
battery, is sized for the gauge of wire that leads from the battery to
the distribution panel. The distribution panel breakers should be sized
to the wire that leads to each piece of equipment. It is ok to make
that fuse smaller than the wire size dictates, and size the fuse based
on the current draw of the equpment.
Commercial - Updated Cambridge 302A Paul Remde Soaring 2 December 16th 04 08:35 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
Cambridge Instruments Ian McPhee Soaring 2 June 18th 04 11:14 AM
Cambridge Aero Explorer Fix Guy Byars Soaring 8 May 19th 04 04:04 AM
Updated IGC approval documents for Cambridge GNSS flight recorders Ian Strachan Soaring 0 August 27th 03 06:28 PM
