Nano 4 GPS BAD/0 satellite reception
Old May 5th 19, 09:26 AM posted to rec.aviation.soaring
HoUdino
Default Nano 4 GPS BAD/0 satellite reception
Is anyone else having problems getting GPS reception with the Nano4? I’ve tried everything I can think of...returned it to the factory, left it on to an open sky for long periods of time, multiple reboots, upgraded software. Still, more often than not “BAD/0”.
Quite frustrating!
Lars T
Old May 5th 19, 01:24 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Quite frustrating!
Lars T
How many GPS receivers are there in the cockpit? How close to this one? Is your fuselage carbon fibre (masks GPS signals)? Have you tried turning off your cellphone? Sounds like GPS interference to me.
Old May 5th 19, 01:31 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Quite frustrating!
Lars T
Another possibility - are you using USB 12 to 5 volt converter in your glider? If yes, is it designed to have low noise? Many are very dirty, and the GPS signal is tiny at the antenna (millionth of a volt). Doesn't take much to hide it. Good converter is https://charge4.harkwood.co.uk/ . I don't have any financial interest...
Old May 5th 19, 05:10 PM posted to rec.aviation.soaring
HoUdino
This is still on a table in the backyard open to the sky on it’s own internal power source.
Nano 4 [email protected] Soaring 9 March 26th 18 05:29 PM
Why no LX Nav Nano IOS App? Sean[_2_] Soaring 8 June 9th 16 02:41 AM
LX-Nano to SN-10B Piet Barber Soaring 8 September 17th 12 06:05 PM
Garmin 496 loss of satellite reception--Garmin's answer Dan Luke Piloting 0 August 22nd 06 06:32 PM
Garmin 496 loss of satellite reception Dan Luke Piloting 5 August 22nd 06 05:30 PM
