ASW-20 B GEAR WARNING SYSTEM
Old May 5th 19, 11:54 PM posted to rec.aviation.soaring
Default ASW-20 B GEAR WARNING SYSTEM
ASW-20 B GEAR WARNING SYSTEM. ANY RECOMMENDATION ON WHAT TO BUY???
Old May 6th 19, 12:47 AM posted to rec.aviation.soaring
Dan Marotta
Something like THIS
https://wingsandwheels.com/landing-gear-warning-kit.html works really
great.Â* If you're electronically inclined, all the parts can be sourced
for a lot less money.Â* The kit, of course, has everything you need at a
reasonable price.
Dan, 5J
Old May 6th 19, 02:03 AM posted to rec.aviation.soaring
Buy?!?! Most build their own, sorta simple.....depends on YOU......
No slam, just saying.......
I have no clue on "bought systems"....I can only comment on "home brew". I would check with UH and T8 on what they do/did.
Old May 6th 19, 04:14 AM posted to rec.aviation.soaring
Tango Eight
On Sunday, May 5, 2019 at 8:03:04 PM UTC-4, Charlie M. (UH & 002 owner/pilot) wrote:
Many higher end varios have provision for gear warning (and that's what I use, just because it's there)... but really, a battery, a beeper and a couple of limit switches will do ya.
Really important: the gear warning needs a defeat switch. Some day -- probably on a ten hour ridge flight -- one of your switches will fail or get jarred loose and the warning will start howling in flight...
T8
Old May 7th 19, 02:41 AM
Delta8 Delta8 is offline
Member
First recorded activity by AviationBanter: Apr 2019
My low budget solution ...a piece of wing tape on the center of the ASI with "Gear?" written on it .
Old May 7th 19, 02:47 PM posted to rec.aviation.soaring
Delta8
A clip that moves from the gear handle to the spoiler handle is another short term option.
UH
Old May 7th 19, 11:26 PM posted to rec.aviation.soaring
UH
A really cheap hair clip (2 for $1.79 at Walmart) works well, but it's not the strongest. Anyone have a recommendation for something a little more stout?
Chip Bearden
Old May 8th 19, 01:29 AM posted to rec.aviation.soaring
Tango Eight
UH
Chip Bearden
Battery charger clip.
T8
Old May 8th 19, 07:50 AM posted to rec.aviation.soaring
Mike Smith
Many years ago I fitted a magnetic reed switch system to my glider. I glued
and taped the magnet onto the undercarriage operating arm and located the
reed in a convenient location. This system worked well. I do not own the
glider now but I suspect it is still functioning. Probably would not be
allowed to carry out such a modification now in Europe due to EASA rules.
Regards. Mike
short term option.
UH
not
stout?
Chip Bearden
Cessna 172 gear warning Paul Kassel Owning 0 March 27th 17 05:29 PM
Gear Warning Gadget Guy Soaring 118 November 30th 05 11:43 PM
Gear Warning Gordon Schubert Soaring 11 November 22nd 05 04:27 AM
Gear Warning Gordon Schubert Soaring 0 November 18th 05 09:22 PM
gear warning plus K.P. Termaat Soaring 0 September 8th 03 09:33 AM
