OAT sensor placement
Old May 14th 19, 03:39 PM posted to rec.aviation.soaring
Rob Shepherd
Default OAT sensor placement
Where would be the best place to install an OAT sensor?
I'm assuming somewhere on the underside of the glider but out of the
airstream.
Constructive comments appreciated.
Cheers
Rob
Old May 14th 19, 03:52 PM posted to rec.aviation.soaring
I know some just put them in the tubing for a front cockpit vent, this a constant outside airflow. This can be in the nose opening (if you have one) or the channel on the cockpit sides from NACA ducts on the fuselage under the wings.
I am sure you will get many more comments.
Old May 14th 19, 07:12 PM posted to rec.aviation.soaring
Dan Marotta
I've installed them in 3 gliders.Â* In the LS-6a and the LAK-17a, I
installed them in the nose vent.Â* My Stemme has a NACA vent on the under
side of the fuselage just about where the pilot's knees are. There's a
removable panel which grants access to the inner surface of the vent.Â* I
simply drilled the proper size hole, glued the temperature probe in the
hole, and ran the wires to the instrument panel.Â* Easy peasy!
airstream.
Cheers
Rob
Dan, 5J
Old May 14th 19, 09:15 PM posted to rec.aviation.soaring
What are the implications of not having the sensor directly in an outside airflow stream - other than getting an incorrect temperature reading. What calculations are dependent on the OAT and how will they be affected by having an incorrect temperature?
Robert
airstream.
Cheers
Rob
Dan, 5J
Old May 14th 19, 09:24 PM posted to rec.aviation.soaring
Dave Nadler
At the very beginning of the air vent intake is usually OK.
Absolutely not further back in the vent channel, as the
indicated temperature will be much higher than OAT when
the vent is closed.
OAT is needed for air density, in turn needed for true airspeed.
Without density corrections many calculations like STF and estimated times
will be wrong (as unfortunately in some popular open source software).
True airspeed must be accurate for good wind calculations.
Number one reason folks have poor wind indication on ILEC SN10
is poor OAT installation, usually because they placed the sensor
in vent duct way behind intake.
Hope that helps!
Best Regards, Dave
PS: If you want to better understand the density effects, it's included he
https://edwilliams.org/avform.htm
Doesn't have glider polar calculations (left as an exercise for the reader ;-)
Old May 15th 19, 02:27 PM posted to rec.aviation.soaring
In the airstream is probably best, since it's hard to measure temperature with an electronic device.
The airstream helps to cool the heat your sensor produces. In the case of a sensor with digital readout, this is influenced by how often you take a measurement.
O2 sensor? Blueskies Home Built 16 July 3rd 07 04:36 PM
Nav Antenna Placement Jim Pensinger Home Built 7 October 4th 04 09:55 PM
Westach 720-4a sensor Ira Rampil Home Built 1 June 21st 04 03:41 AM
temperature sensor Philippe Vessaire Home Built 2 March 3rd 04 03:37 AM
Ki-100 armament placement N-6 Military Aviation 2 October 18th 03 12:09 AM
