Cobra Trailer Brakes
Old May 18th 19, 11:23 PM posted to rec.aviation.soaring
Default Cobra Trailer Brakes
Having just installed new brake drums, bearings, backing plates, and brakes on my 2011 year Cobra (New because I burnt up the original ones on the way to Perry, a long post on that later) I am quite sensitive to how hot the brakes should get in normal operation.
I am sure that all the new items were installed properly and the adjustments were checked and are correct.
Taking the trailer from home to SCOH is a 60 mile trip. The first half is rural but with quite a few stop signs and traffic lights. I stopped several times to check and the brake hubs were hot (and I would expect some heat due to friction, physics, and all that) but how hot is too hot? I could put my finger on the hub but didn't want to keep it on much longer than a second. By comparison the brake rotors on the tow vehicle were considerably hotter than the trailer brake drums.
At one checking stop I jacked up each side and the wheels turned freely with no sound of brakes rubbing.
The second half of the trip was open highway and upon arrival at the field the brake drums were still warm, but considerable less than the stop and go portion of the trip.
The trailer tongue compresses when stopping and expands when moving in what I assume is the normal manner. I did test how much force it takes to depress the movable portion of the tongue, unhitched from the tow vehicle, and it seemed to me about 75 pounds. When released the tongue then moved out to its full extension but did take about 10 seconds to do that.
So, having said all this, is this normal operation or is something amiss?
Next time I tow the trailer I will take actual temp readings with a thermal scanner and report actual temps.
DVM
ASG29E BV
Old May 19th 19, 01:29 AM posted to rec.aviation.soaring
Charles Longley
Disconnect the brakes and take it like a man!
Old May 19th 19, 04:47 AM posted to rec.aviation.soaring
I had similar results after a long down hill drive that lasted maybe 30 minutes. I was down shifting, but ran about 40 mph. As I gassed up I checked the hubs and they were alarmingly hot. Didn’t want to keep my finger on the hub more than a second. After driving for another hour on level ground, they both were just warm. I concluded it was caused my the down hill run, where the surge brake was being applied because the tow vehicle was slowing down due to down shifting. Nothing else to the issue for the next 5 years.
Hope this helps,
JJ
Old May 19th 19, 02:00 PM posted to rec.aviation.soaring
Nelson Howe
DVM
ASG29E BV
I had to replace the pads and bearings last year because of overheating. Even after the replacement I found my hubs getting pretty warm on a short drive. We then removed the bowden cables, lubed them, got them moving freely and easily, and reinstalled them. That fixed the problem and the hubs now feel just a little warm to the touch after driving, not hot. I have a new set of bowden cables I plan to install in the future.
Nelson
Old May 19th 19, 06:39 PM posted to rec.aviation.soaring
Pads....???!!! I thought all were drum brakes!
Old May 19th 19, 08:24 PM posted to rec.aviation.soaring
Nelson Howe
Sorry, shoes then.
Old May 19th 19, 09:30 PM posted to rec.aviation.soaring
Charles Longley
That just sounded wrong lol sorry! I have two Kobra trailers now. One with brakes and one without. I am not sure what type of axle the one without brakes has. Is it possible to put electric brakes on a Kobra trailer? Has anyone done it?
Old May 19th 19, 10:59 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Charles
I think others have had good success with DEXTER AXLES
Don't forget to get a spare that fits and you'll have to install a Brake Controller.
This is the route I am going to take soon, maybe this summer, as my Cobra brakes are FUBAR
And I like the idea of Electric brakes on my trailers.
Old May 20th 19, 03:13 AM posted to rec.aviation.soaring
Matt Herron Jr.
Monitor trailer and car tires for pressure and temperature for $200
https://www.amazon.com/Pressure-Moni...ct_top?ie=UTF8
Will a hot drum heat up the rim, then the tire so temperature at the valve stem is meaningful???
Old May 20th 19, 12:10 PM posted to rec.aviation.soaring
It wouldn't hurt to watch temps. Tire pressure will change by about 1PSI/10*F.
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
cobra wheel bearings and brakes [email protected] Soaring 4 August 13th 12 11:21 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
Cobra surge brakes on mountain grades. [email protected] Soaring 12 May 21st 07 02:15 AM
Cobra Trailer brakes R Barry Soaring 22 July 19th 04 04:51 PM
