Tost Lilliput brake question
Old May 21st 19, 01:28 PM posted to rec.aviation.soaring
Hartley Falbaum[_2_]
Default Tost Lilliput brake question
I am trying to improve the brakes on a Libelle 201B. I replaced the shoes and de-glazed the drum recently but not much help.
I trued the drum on a mandrel in a 10" Clausing lathe. I mounted the backing plate and shoes on another mandrel, intending to true the shoes, but got readings that told me the shoes would have to be expanded.
I had no good way to do that without getting excessive clearance. So I just deglazed them.
After installation, I had to max-out the one adjuster in order to get the proper tension on the handbrake.
I noticed a threaded hole in the brake handle, centered on the cable. Looks like a setscrew belongs there for adjusting cable length.
So--here's my question-----What style of setscrew point belongs there? Flat tip, or dog point (extended tip). I presume a cup point would damage the cable.
Thanks in advance for any factual knowledge.
Hartley Falbaum
hfalbaum at comcast dot com
Old May 21st 19, 02:45 PM posted to rec.aviation.soaring
If memory serves me, the Libelle only had an adjustment at the wheel. Guess you could add one at the stick? You may want to move the arm on the brake one spline to make it closer to brake application.
Hope this helps,
JJ
Old May 21st 19, 03:48 PM posted to rec.aviation.soaring
AS
Hartley Falbaum
You could also look for a brake shop that does specialize in rebuilding classic car and motorcycle brakes. They can re-line the shoes with a more 'grabby' material and match the brake shoe radius with the diameter of the drum..
When adjusting the cable on the wheel end, make sure that the cable and the arm are at a 90° angle when the linings start to touch the drum. As JJ mentioned, that may require the removal and readjustment of the lever by one or two teeth on the conical spline. Put a common mark on the shaft and the lever so you know where you started out from.
Good luck,
Uli
'AS'
Old May 21st 19, 05:28 PM posted to rec.aviation.soaring
Tim Taylor
In general you will also find that there is not enough movement in the handle to move the arm far enough to provide adequate braking unless the brake is adjusted to touching the drum at rest. After deglazing, I adjust the cable until there is a light dragging with with the handle in the fully open position. The handle should have almost no movement to provide full braking.
Old May 21st 19, 05:55 PM posted to rec.aviation.soaring
JS[_5_]
Uli
'AS'
There are not many places that work on drum brakes any more. The place I had used in Los Angeles is gone.
We used the shop below for a Libelle 201b brake, with fabulous results.
Be careful not to put it over on the nose afterwards!
Vintage get really busy. Best to book it and pay, then send the wheel when they're ready.
But its a bad time of year unless you have a spare wheel.
Vintage Brake
Michael Morse
15069 Lupine Lane
Sonora, CA
USA
209 533-4346
info AT vintagebrake DOT com
www DOT vintagebrake DOT com
Old May 21st 19, 06:43 PM posted to rec.aviation.soaring
Vintage Brake is great, but I’m thinking your a do it yourself guy. You can “ spike” your shoes, by gluing 40 grit sandpaper to the drum, then actuate the brake and hand spin it around the drum. This will take a while, but eventually the shoes will match your drum. Spiking is the most important thing to get good breaking. As delivered, most shoes only touch one end of one pad, little wonder the breaking action sucks!
Have fun and don’t forget to remove the sandpaper,
JJ
Old May 21st 19, 06:49 PM posted to rec.aviation.soaring
Hartley Falbaum
Good suggestion!
The Lilliput brake arm is really hard to change spline alignment due to the coil spring around the base.
But my question was about a possible set screw in the handle to adjust the brake. appears to be M6-1.0.
could be used to adjust cable length, but the screw is missing. The threaded hole is there. Does anyone know for sure about this?
Thanks
Old May 21st 19, 07:00 PM posted to rec.aviation.soaring
No idea if this is original or not but the brake cable setscrew in my Libelle is a flat tip style. I haven't had any issue with the cable getting cut but it does flatten out the cable such that it becomes difficult to reuse a second time should you ever remove it. I have a mid-cable adjuster in addition to the adjuster nuts on the wheel end and it seems to give plenty of adjustment to keep things working well.
Robert
Hartley Falbaum
Good suggestion!
Thanks
Old May 21st 19, 07:19 PM posted to rec.aviation.soaring
Hartley Falbaum
Thanks!
Old May 21st 19, 09:24 PM posted to rec.aviation.soaring
Wheaton
You won't believe this but as good a solution is on eBay for $15.00. Search for EBC 303 Brake shoes. You may need to machine a little to fit drum, but lining material is softer than the $90 Toast replacement. Thus, they don't glaze up as quick. Uncanny in that the cast, springs and other that the brake material are identical.
Still not a perfect solution, but if you are gentle on the brakes you can go a full season.
Enjoy and buy a beer with what you save.
Joe
Looking for Tost Standard Drum Brake Wheel (USA) [email protected] Soaring 2 March 28th 19 12:11 PM
Modifying Std Libelle with Tost Lilliput Wheel [email protected] Soaring 10 September 19th 17 06:51 PM
Tost Disk Brake rebuild? Paul Cordell Soaring 10 April 17th 08 07:20 AM
Tost brake bolt shears off - the answer Jack Glendening Soaring 1 September 30th 07 01:16 PM
Tost brake bolt shears off Jack Glendening[_2_] Soaring 25 September 10th 07 10:15 PM
