Oratex
Old July 26th 19, 11:53 PM posted to rec.aviation.soaring
Andrew Fletcher
Default Oratex
Has anyone used Oratex to cover a glider here?
If so what was your experience both in applying and then the finished
product compared to the traditonal way.
I have a K6 wing that I am about to cover.
Old July 27th 19, 10:35 PM posted to rec.aviation.soaring
Charles Longley
Default Oratex
I have no experience with it but have used most of the other processes. I know it’s quite a bit more expensive then anything else.
Here’s a good discussion on the Super Cub site-
https://www.supercub.org/forum/showt...ghlight=Oratex
Old July 29th 19, 05:34 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
Default Oratex
This looks very promising for fabric covered gliders, very light and easier to use then other systems. Keep in mind tho that if your glider is certified (vs. experimental) it will need a basis of approval, either an STC or a field approval. Might want to check with Oratex to see if anyone has gotten an approval for there K6.
