FAA ADSB Performance Website Working??
Old July 29th 19, 03:58 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
Default FAA ADSB Performance Website Working??
Has anyone gotten the FAA ADSB Performance website to work recently?
https://adsbperformance.faa.gov/PAPRRequest.aspx
It worked fine for me last year, but multiple attempts recently to
file a report results in a return to the original input screen when
you press "Submit Request" at the bottom of the page.
Bob
Old July 30th 19, 06:11 PM posted to rec.aviation.soaring
Scott Williams
Bob
Hey Bob,
I've pulled several reports in the last few weeks, works fine,
Occasionally I forget to enter info in all the boxes, especially the 2nd emitter category, "not installed"
good luck,
Scott, STD Cirrus, standard category pure glider, ADS-B out
Old July 30th 19, 06:31 PM posted to rec.aviation.soaring
Dan Marotta
Scott had the right answer.Â* I just got a report for yesterday's flight.
Bob
Hey Bob,
good luck,
Dan, 5J
Old July 31st 19, 12:12 AM posted to rec.aviation.soaring
Scott Williams
Bob
Hey Bob,
good luck,
Dan, 5J
https://adsbperformance.faa.gov/paprrequest.aspx
I wonder if it's caps sensitive?
Old July 31st 19, 05:13 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
On Tue, 30 Jul 2019 09:11:41 -0700 (PDT), Scott Williams
Bob
Hey Bob,
good luck,
Thanks Scott, looks like that is the issue. I neglected to select "not
installed" for the "Enter 2nd GPS" field.
Got the report back in a few minutes.
Thanks
Bob
ADSB out in tow planes Charles Longley Soaring 57 June 5th 18 05:39 AM
Stratus / Foreflight ADSB 6X Soaring 5 December 17th 13 10:34 AM
ADSB is only the start... Martin Gregorie[_5_] Soaring 0 October 1st 09 02:27 PM
Santa and ADSB Mal Soaring 0 December 15th 06 08:42 PM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 09:04 AM
