Instrument tubing
Old August 7th 19, 05:12 PM posted to rec.aviation.soaring
soaringjac
Default Instrument tubing
Where does one get those "doughnuts" that you put over instrument tubing to help secure and seal the connection?
Old August 7th 19, 05:17 PM posted to rec.aviation.soaring
Dan Marotta
I've used safety wire for that purpose, being careful not to make it too
tight.
Dan, 5J
Old August 7th 19, 05:29 PM posted to rec.aviation.soaring
Peter F[_2_]
Vet
Agricultural supplier
ebay
They're intended to do nasty things to sheep
to
Old August 7th 19, 06:11 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Don't waste your time using those they are not needed.
Richard
Old August 7th 19, 06:27 PM posted to rec.aviation.soaring
Tango Whisky
Exactly. Tubing should be silicone. No additional devices needed.
Old August 7th 19, 09:46 PM posted to rec.aviation.soaring
soaringjac
I plan on using the colored tubing from Wings and Wheels. Good stuff?
Old August 7th 19, 10:01 PM posted to rec.aviation.soaring
Absolutely, very good tubing!
Old August 7th 19, 11:29 PM posted to rec.aviation.soaring
Craggy Aero also has tubing
http://www.craggyaero.com/tubing_&_fittings.htm
Richard
www.craggyaero.com
Old August 8th 19, 03:48 AM posted to rec.aviation.soaring
Charlie Quebec
I use silicon tube of 5mm ID cut into 10mm pices and stretched over the tube and fitting.
The rubber donuts deteriorate very quickly to the point of being useless.
Old August 8th 19, 03:49 AM posted to rec.aviation.soaring
Charlie Quebec
The rubber rings are called docking rings.
Source of green donuts for instrument tubing installation? Movses Babayan Soaring 14 April 10th 18 10:45 PM
Relesable instrument tubing [email protected] Soaring 6 February 13th 07 06:38 AM
source for clear+red instrument tubing John W Soaring 8 November 1st 04 02:19 PM
Tubing strength Ernest Christley Home Built 0 January 17th 04 12:43 AM
