Wanted to buy, Dittel radio wiring harness
Old September 7th 19, 04:36 PM posted to rec.aviation.soaring
Chuck Lohre[_2_]
Default Wanted to buy, Dittel radio wiring harness
Hi All,
Trying to figure out what is wrong with my system and would like a harness to test the radio, Dittle speaker box, and Dittel mic, push to talk outside the glider. Please email me chuck at lohre dot com or call 513-260-9025. Thanks.
Old September 8th 19, 01:40 PM posted to rec.aviation.soaring
Ross[_3_]
What Dittel radio do you have and what are the issues you are having?
Old September 8th 19, 06:08 PM posted to rec.aviation.soaring
Chuck Lohre[_2_]
It's an FSG2T. I can received but can't send. Going to try a different mic. Thanks for the post.
Old September 8th 19, 08:21 PM posted to rec.aviation.soaring
Ross[_3_]
I probably have a dynamic mic in the workshop that would match it well.
Let me know if you have no success.
If it happens to be the radio I can also assist with a replacement or repair
Old September 9th 19, 12:59 AM posted to rec.aviation.soaring
Chuck Lohre[_2_]
Thanks for the offer. I'll get in touch after I've done some testing.
Old September 9th 19, 01:50 AM posted to rec.aviation.soaring
On Saturday, September 7, 2019 at 8:36:30 AM UTC-7, Chuck Lohre wrote:
Hi All,
I'm guessing you are looking for used and sure you already know, but Cumulus sells the wiring harness for $130 and the speaker box for $155.
https://www.cumulus-soaring.com/dittel.htm#F10028
Old September 9th 19, 02:23 PM posted to rec.aviation.soaring
Chuck,
While making or buying a harness is an option, I think that you may be pursuing the wrong approach to your problem.
You have a problem in your glider. You want to set up a bench test rig. This will only determine if the radio itself is ok or not. In my experience the radio itself doesn't fail - especially so with quality brands (Filser, Dittel, Becker, etc) but rather with wiring, power supply, antenna, etc. Bottom line: your intended approach probably won't determine where your problem is within the glider.
My suggestion is to first use the troubleshooting guidelines in my presentation http://aviation.derosaweb.net/presen...s/#transceiver and see where that gets you.
If you think the problem is with the radio then send it in to a qualified repair shop. Addresses and phone numbers are listed in my presentation.
Best of Luck,
John OHM Ω
Old September 10th 19, 04:10 PM posted to rec.aviation.soaring
2G
On Monday, September 9, 2019 at 6:23:52 AM UTC-7, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
Chuck,
Best of Luck,
John OHM Ω
A handy instrument to have is an SWR meter, and they are pretty cheap. This will show any faults in the antenna lead (the most likely wiring fault).
Tom
Old September 10th 19, 05:29 PM posted to rec.aviation.soaring
Chuck,
You have a problem in your glider. You want to set up a bench test rig.. This will only determine if the radio itself is ok or not. In my experience the radio itself doesn't fail - especially so with quality brands (Filser, Dittel, Becker, etc) but rather with wiring, power supply, antenna, etc. Bottom line: your intended approach probably won't determine where your problem is within the glider.
Best of Luck,
John OHM Ω
Tom
Tom - Thanks. Yes, an (V)SWR meter is a handy tool for those technical folks.
To explain - This meter will measure how well your various "antenna system" components (transceiver, BNC connectors, coax wiring, and antenna) are all working together. Any one component of which can cause transmit issues - especially suspect are the BNC connectors.
Simply said, the meter will indicate if things are not right by showing a high numerical reading. Anything above ~1.5 is suspect. The lower the number, 1.0 being best, the more transmit power is actually reaching the antenna.
A (simple testable) effect of having a lousy antenna system is the transceiver will draw much more current than usual which usually shows up by the battery voltage dropping from ~12Vdc to ~10Vdc or worse.
For the receive side nearly anything will work fairly well, at least for close-in transmissions.
Hey, that sounded pretty intelligent! I should add this to my presentation!!!
- John OHM Ω
Old September 10th 19, 05:39 PM posted to rec.aviation.soaring
Chuck,
Best of Luck,
John OHM Ω
Tom
Thanks Tom, I'll look into it.
Wiring Harness Needed Bob Youngblood Soaring 12 September 6th 19 10:58 PM
Dittel Dynamic Mic wiring Doug Mueller Soaring 10 February 7th 15 01:41 AM
engine monitor wiring harness install Jim Burns Owning 8 November 20th 06 02:26 PM
Dittel Radio wanted Paul Soaring 2 August 28th 05 03:12 PM
looking for Dittel FSG 60M wiring diagram ken ward Soaring 1 May 29th 05 02:54 AM
