Libelle 201A POH
Old September 9th 19, 02:16 AM posted to rec.aviation.soaring
Default Libelle 201A POH
I recently have been given access to a friends Libelle model A. I think the Serial number is #83, Unfortunately, the POH is lost. Could anyone send me a copy or e-file of this document?
Thank You
Dennis
Old September 9th 19, 09:53 AM posted to rec.aviation.soaring
Thank You
Dennis
maybe you don't need one... depends what year it was build
https://backcountrypilot.org/forum/p...-question-4290
Old September 9th 19, 02:31 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
I have s/n 82. I was flying it yesterday off the winch and easily
outclimbing clubmates.
Any Libelle 201 POH should be fine - my copy is for a 201B. In the UK it
was decided that the difference between a 201 and a 201B is small enough
that 201B W&B limits can also apply to a 201. That means we use the same
weak links, CG positions, seat loads and max flying weights etc. despite
the B series having different airbrakes, tailplane and, of course, using
foam in flying surface skins instead of balsa and having water ballast
bags as a standard option.
The only place where I'd treat the 201 and 201B differently is carrying
water ballast. I won't carry water in mine (no water system anyway)
because I heard that a number of 301s were destroyed when the combination
of leaky water bags and porous inner surface to the wing skins allowed
the balsa wing skin cores to rot.
A copy of the 201B POH is in the way.
Martin | martin at
Gregorie | gregorie dot org
Std. Libelle vs Club Libelle [email protected] Soaring 10 August 21st 19 02:00 AM
New - Libelle for Condor 2 Paul Remde Soaring 0 February 28th 19 02:35 AM
Libelle Ross[_3_] Soaring 38 August 13th 18 09:23 PM
Std. Libelle Rigging Kit Roger Fowler[_3_] Soaring 4 January 3rd 15 03:22 PM
Libelle Canopy Tom Watson Soaring 4 February 28th 12 12:59 AM
