A wooden control stick grip
Old September 14th 19, 04:32 AM posted to rec.aviation.soaring
Tom BravoMike
Default A wooden control stick grip
The grip in my 1984 Ventus is worn out and a bit sticky. I have always thought it would be nice to have a wooden one, e.g.:
https://www.cps-parts.com/catalog/el...ipstandard.php
Anyone has tried something like that? Are they much bigger/thicker than the factory ones? BTW, which inner size is it, 3/4" or 7/8" (before I get to the glider to measure it myself?) Thanks in advance for sharing your thoughts.
Old September 14th 19, 04:41 AM posted to rec.aviation.soaring
Tim Taylor
I had a wooden one similar to the link in a Ventus b. It was ok, but I found it a little large. I tend to fly holding the stick in several different ways depending on the conditions. The wooden one was fine when you are holding the stick near the top, but it did not work as well when you wanted to have just a few fingers at the base.
Old September 14th 19, 08:25 AM posted to rec.aviation.soaring
Eric Munk
I think you’ll find it’s metric.
Old September 14th 19, 02:52 PM posted to rec.aviation.soaring
If you make a plug to hold the ptt switch, then foam bicycle handlebar tape works great.
Old September 14th 19, 07:45 PM posted to rec.aviation.soaring
Tom BravoMike
Yes, I've been looking at some interesting bike grips, too. Some claim those made of cork are even better than the wooden ones:
https://ergonbike.myshopify.com/coll...ts/gp1-biokork
Old September 15th 19, 02:21 AM posted to rec.aviation.soaring
Scott Williams
I also was less than thrilled with the original ski pole grip commonly used on SH gliders. In my search for a suitable replacement, I found a few options which were either unobtainable or expensive. I only need a PTT and once read that U.S. military stick grip have been molded from black pigmented plexiglass since WWII. so I carved out a couple using a belt sander and polished them. I also carved out a phenolic version. I used a PTT "otto" brand switch.
pics on clubs facebook page
https://www.facebook.com/groups/381501291867080/
Old September 15th 19, 04:45 AM posted to rec.aviation.soaring
Tom BravoMike
Sorry, but I belong to that minority species who has chosen not to have a FB account, hence no access. But thanks all the same.
Old September 15th 19, 07:13 AM posted to rec.aviation.soaring
Chris Wedgwood[_2_]
It wouldn't help anyway. Thats a closed group page. Goodness knows what they are trying to keep secret from the rest of us
Old September 15th 19, 11:24 PM posted to rec.aviation.soaring
Wrapping the existing grip with Tennis Racquet " grip wrap" worked nicely for me in a Standard Cirrus with that sticky grip problem.
Old September 16th 19, 02:10 AM posted to rec.aviation.soaring
Scott Williams
So FB closed? how about SSA,
https://www.ssa.org/photogallery.asp...mbr=1392883062
Wooden ClearNav stick grip Dan Mockler Soaring 0 November 13th 17 10:53 PM
adding speed/vario switch into ASW-19 control stick grip Kimmo Hytoenen Soaring 15 December 21st 12 11:54 PM
adding speed/vario switch into ASW-19 control stick grip Kimmo Hytoenen Soaring 0 December 19th 12 01:28 PM
control stick (complete not only grip) from mig-21 papcio Aviation Marketplace 0 May 3rd 04 07:08 PM
FA Infinity Military Style Control Stick Grip Terry Ladouceur Home Built 3 October 8th 03 12:52 AM
