Skysight
Old September 14th 19, 03:21 PM posted to rec.aviation.soaring
Dan Marotta
Default Skysight
Looking at today's forecast for Moriarty, NM, USA for 1300 local time
brings up a question.Â* I've always considered the thermal height, cloud
base, etc., to be MSL altitudes.Â* Indeed, looking directly at Moriarty
shows 11,500' which is reasonable given the time and date.
Moving a bit west, however, to the area of Edgewood, shows a blue blob
with an indicated altitude of 2,500'.Â* Now I know Edgewood's elevation
to be somewhat above 6,000' MSL.Â* So is there a big hole in the ground
that I haven't seen, is the height of thermals in AGL, is there an error
in the program, or am I missing something?
Inquiring minds and all...
Dan, 5J
Old September 14th 19, 09:51 PM posted to rec.aviation.soaring
Default Skysight
Dan, 5J
I would suggest directing these types of inquiries to us directly at , preferably with a screenshot.
In this case though, I think what you are seeing is an unintended consequence of Height of Thermals being set to 0 rather than terrain height when there are no thermals in a given location. This is intentional so you get nice clear/unfilled holes demarcating areas of no thermals rather than a potentially misleading colour value in areas of high topography. But then in the final stage of rendering there's a small degree of smoothing which is 'smearing' that zero value back to a positive, but below ground value. It probably should know to not smooth zero value areas, that will get fixed at some point.
New Skysight Color Dan Marotta Soaring 6 June 29th 19 02:48 PM
Skysight Question Dan Marotta Soaring 3 August 12th 18 01:21 AM
SeeYou V.9.0 and SkySight Dan[_6_] Soaring 6 November 8th 17 03:21 PM
SkySight forecast available for SW USA JS Soaring 16 April 22nd 17 12:33 PM
Skysight Tom Kelley #711 Soaring 0 April 5th 17 07:09 PM
