Ilyushin Il-96
Old May 11th 19, 03:48 PM posted to alt.binaries.pictures.aviation
Miloch
Default Ilyushin Il-96
https://en.wikipedia.org/wiki/Ilyushin_Il-96
The Ilyushin Il-96 is a Russian quadjet long-haul wide-body airliner designed by
Ilyushin in the former Soviet Union and manufactured by the Voronezh Aircraft
Production Association in Russia. It is powered by four Aviadvigatel PS-90
two-shaft turbofan engines.
The Ilyushin Il-96 is a shortened, long-range, and advanced technology
development of the Soviet Union's first widebody airliner, the Ilyushin Il-86.
It features supercritical wings fitted with winglets, a glass cockpit, and a
fly-by-wire control system. It was first flown in 1988 and certified in 1992.
The basic Il-96-300 is equipped with modern Russian avionics integrating six
multi-function colour LCD displays, inertial and satellite navigation systems,
and a Traffic Collision Avoidance System (including mode "S"). It allows the
airplane to be operated with two crew members. The avionics correspond to modern
requirements on international routes in Europe and North America (RNP-1) and
allow navigation and landing under ICAO CAT III/A conditions. The Il-96 is
offered in three main variants: the Il-96-300, Il-96M/T and Il-96-400.
The Il-96-300 has a standard passenger capacity of 262 seats in a two-class
configuration with 18 seats with a seat pitch of 54 inches (140 cm) and 244
seats with a pitch of 32 inches (81 cm), of which typical seating is 3-3-3
(layout), but low density seating is possible with 2-4-2 (layout). Galleys are
positioned on the upper deck, and the lower deck can accommodate 18 LD-3
containers and crew rest areas.
In June 2005, the Volga-Dnepr Group signed a 15-year financial agreement with
Ilyushin Finance Corporation (IFC) to take delivery of two new-build Il-96-400T
aircraft, to be operated by Volga-Dnepr's subsidiary AirBridge Cargo. The first
was due to have been delivered in late 2006.
Role
Widebody jet airliner
Manufacturer
Voronezh Aircraft Production Association
Design group
Ilyushin
First flight
28 September 1988; 30 years ago
Introduction
29 December 1992 with Aeroflot
Status
In low-rate production, In service
Primary user
Cubana
Produced
1992–present
Number built
30
Unit cost
US$ 40–50 million
The Cuban Government newspaper Granma announced on 3 January 2006 the first
official flight of the Cubana Il-96-300, from Havana to Buenos Aires, Argentina.
On 11 August 2009 Russian Minister of Industry and Trade Viktor Khristenko
announced that manufacturing of the Il-96-300 would cease. In particular, the
Il-96-300 had been deemed inferior to counterparts from Boeing and Airbus, and
the manufacturer could not arrange commercially viable mass production, making
only one aircraft per year. The Il-96-400T cargo version was to remain in
production.
On 9 October 2015, it was announced that an updated version of the Il-96 may be
produced. This decision was taken due to the current diplomatic situation
between Russia and the West, and the dependency of the Russian Aerospace
Industry on Airbus and Boeing. In September 2017, the Vice President of Russia's
United Aircraft Corporation Aleksandr Tulyakov announced the start of
development of the 250-280 seat, wide-body long-haul aircraft in partnership
with Chinese builders. The aircraft is to be a development of the
Russian-designed IL-96 and will be assembled in China. A new engineering center
will be built in Russia to undertake technical and electronics production.
Specifications
Il-96-300
Length 55.3 m (181 ft 7 in)
Span 60.11 m (197 ft 3 in)
Wing area 350 m² (3767.9 ft²)
Wing sweep 30°
Flaps/Slats I – 2°/3° (275 KIAS), II 3°/25° (264 KIAS), III – 10°/25° (243
KIAS),
IV – 25°/25° (210 KIAS) for Takeoff, V – 40°/25° (189 KIAS) for Landing
Cabin width 5.70 m (18.70 ft)
Fuselage Diameter 6.08 m (19.94 ft)
Height 15.7 m (57 ft 7 in)
Operating Empty Weight 120,400 kg (265,198 lb)
Max. Zero Fuel Weight 180,000 kg (403,000 lb) 208,400 kg (459,030 lb)
Max. Landing Weight 183,000 kg (403,083 lb)
Max. Take-off Weight 250,000 kg (551,000 lb)
Max. Payload 40,000 kg (88,105 lb)
Takeoff Run at MTOW 2,340 m (7,677 ft)
Landing Run 860 m (2,821 ft)
Cruising speed 0.78 to 0.84 Mach or 850 to 870 km/h TAS (459 to 469 KTAS)
Maximum speed (Vmo) 0.84 Mach or 900 km/h IAS (485 KIAS)
Service ceiling 13,100 m (43,000 Ft)
Cruise Altitude 9,000 to 12,000 m (29,527 to 39,370 Ft)
Range with max. payload 11,500 km (6,209 nmi) 12,800 km (6,907 nmi) 5,000 km
(2,699 nmi) 10,000 km (5,400 nmi)
Range with max. fuel 13,500 km (7,289 nmi) 15,000 km (8,100 nmi) 12,000 km
(6,479 nmi) 12,000 km (6,479 nmi)
Max. Fuel capacity 152,620 l (40,322 US gal)
Engines (x4) Aviadvigatel PS-90A Pratt & Whitney
PW2037 Pratt & Whitney PW2337
or
Aviadvigatel PS-90A1 Aviadvigatel PS-90A1
Thrust (x4) PS-90A: 156.9 kN
(35,242 lb)
N2:10,425 RPM 170.1 kN
(38,250 lb)
N2:12,360 RPM PW2337: 166.8 kN
(37,500 lb)
N2:12,360 RPM PS-90A1: 170.7 kN
(38,326 lb)
Engine Dry Weight (x4) 2,950 kg
(6,497 lb) 3,314 kg
(7,300 lb) PW2337: 3,314 kg
(7,300 lb) 2,950 kg
(6,497 lb)
Cockpit crew Three Two Two (op. Three)
Ilyushin DB-3 pics 2 [3/7] - Ilyushin-DB-3-only-surviver-Central-Museum-Monino-Russia-03.jpg (1/1) Miloch Aviation Photos 0 October 1st 18 04:10 PM
Ilyushin Il-18 / Il-20 / Il-22 pics [09/10] - Ilyushin Il-20M - Russia - Air Force (2).jpg (1/1) Miloch Aviation Photos 0 September 20th 18 04:18 PM
Ilyushin Il-18 / Il-20 / Il-22 pics [08/10] - Ilyushin IL-18 cutaway drawing.jpg (1/1) Miloch Aviation Photos 0 September 20th 18 04:18 PM
Ilyushin Il-28 pics 2 [2/3] - This is a Russian Ilyushin Il-28 'Beagle' bomber licence built in China as the Harbin (where the factory is) H-5..jpg (1/1) Miloch Aviation Photos 0 June 30th 18 03:51 PM
Ilyushin Il-10 pics 2 [5/5] - Korean Ilyushin Il-10 Sturmovik.jpg (1/1) Miloch Aviation Photos 0 March 28th 17 04:22 PM
