Ventus 2cxa instrument panel gas spring needed
Old January 10th 20, 03:02 PM posted to rec.aviation.soaring
Ken Sorenson
Default Ventus 2cxa instrument panel gas spring needed
300N, extended length 239mm, Hahn-Gasfedern GmbH Art.Nr. 188872.1 Suggested sources? None yet available from Schempp-USA. Seems like there should be some US sources for these parts. Thanks in advance. Ken Sorenson
Old January 10th 20, 03:08 PM posted to rec.aviation.soaring
Ken Sorenson
Oops Corrected Art. Nr 1107437.
Old January 10th 20, 03:20 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Ken,
You can probably get one he
https://www.acecontrols.com
You will need to specify both the extended, retracted lengths, rod dia, cylinder dia,end fittings,and newtons.
Richard
www.craggyaero.com
Old January 10th 20, 04:24 PM posted to rec.aviation.soaring
Ken Sorenson
Ken,
Richard
www.craggyaero.com
Richard Thanks! I can get close using their configuration tool and catalog. May have to go this route and then modify it. Excellent tip.
Old January 10th 20, 04:38 PM posted to rec.aviation.soaring
I've had luck here
https://www.mcmaster.com/struts
Old January 10th 20, 06:37 PM posted to rec.aviation.soaring
Dan Marotta
Years back I needed the canopy gas spring for my LAK-17a.Â* With some
digging on the internet I was able to cross reference it with the hood
(bonnet) lift spring used on the mid-90s 7-series BMW.Â* Picked one up at
the local Autozone.
On 1/10/2020 9:38 AM, wrote:
I've had luck here
Dan, 5J
Old January 10th 20, 07:22 PM posted to rec.aviation.soaring
Dave Nadler
Hi Ken - I've used Bansbach a few times (also original equipment on some gliders):
http://www.bansbach.com/Bansbach/ind...CcDwQA vD_BwE
Ventus 2cxa with FES LZ design Soaring 55 April 21st 14 09:30 AM
Blank Discus - Ventus Instrument panel for sale james bakeman Soaring 2 September 24th 11 07:30 PM
AS responds to the latest Ventus 2cxa KevinFinke Soaring 3 March 18th 09 03:45 AM
Ventus 1 - anyone have experience w/o aileron centering spring? Gary Emerson Soaring 0 November 1st 08 02:36 PM
PIREP Needed - Aircraft Door Seals Instrument Panel cover Mike Spera Owning 2 June 24th 06 05:02 PM
