SeeYou incorrect waypoint altitudes
Old February 1st 20, 03:59 AM posted to rec.aviation.soaring
soaringjac
Default SeeYou incorrect waypoint altitudes
Just started using seeyou for the first time. I created some waypoints in seeyou and noticed the altitude shown for some of the waypoints are way off. I double checked the exact same point in Google earth and the difference is about 1000'. This isn't the case for all custom waypoints I made, but it is true for most of them. How are you guys creating accurate waypoints and waypoint altitudes. Kind of crazy that seeyou is so off!
Old February 1st 20, 08:49 AM posted to rec.aviation.soaring
Paul Ruskin[_2_]
waypoints in
s=
way
off.=
difference
i=
but it
waypoints and
Are you getting confused between metres and feet? See you will work
in either and will convert between them.
Paul
Old February 1st 20, 03:14 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I suspect that one of 2 things is happening.
- You may be using a bad turnpoint database. I recommend the data found he
http://cumulus-soaring.com/seeyou.htm#Downloads
- If you are viewing a flight log, SeeYou can automatically use the take-off and landing elevations and the SeeYou ground elevation database to offset all the flight log points to account for barometric pressure changes. It is a very nice feature.
You may want to check-out my SeeYou Tips document.
http://cumulus-soaring.com/seeyou/SeeYou-Tips.pdf
Best Regards,
Paul Remde
Old February 1st 20, 03:33 PM posted to rec.aviation.soaring
soaringjac
waypoints in
s=
way
off.=
difference
i=
but it
waypoints and
Paul
its definitely showing me feet
Old February 1st 20, 03:38 PM posted to rec.aviation.soaring
soaringjac
On Saturday, February 1, 2020 at 7:14:46 AM UTC-8, Paul Remde wrote:
Hi,
Best Regards,
Paul Remde
Thanks Paul! I am not using any turnpoint database and not viewing any flight log. I am just trying to mark some local landmarks as waypoints to put into my S100 vario. Im going to play around with it a bit more and see if i can figure out whats going on, but to me it seems like the see your elevations are not accurate. I guess i can always create the waypoints and then edit their altitudes based on the alt i get from google earth, which kind of sucks
Old February 1st 20, 03:48 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
soaringjac wrote on 1/31/2020 7:59 PM:
For what purpose will you use the waypoints? If it's for task planning, the
correct elevation doesn't matter; if it's for potential landing places, you should
not depend on SeeYou, but on a more accurate source. SeeYou is a flight planning
tool, and it's your flight computer that needs elevation accuracy. I use official
databases as my first choice; for landing places not in the official databases, I
use databases from pilots I trust, sometimes from Google, perhaps topographic
maps. I also plan to arrive higher at those landing places, partly because the
elevation may not be known as accurately as airports on the charts.
Old February 1st 20, 05:43 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Hi,
found he
Best Regards,
Paul Remde
Post one of the problematic turnpoints here so we can see what might be
wrong. CUP files are just plaintext, so almost any program that can
display a text file can display it for cut'n pasting - even Word.
Martin | martin at
Gregorie | gregorie dot org
Old February 1st 20, 07:48 PM posted to rec.aviation.soaring
Darryl Ramm
Describing exactly wha you are doing and providing sample data will help you get useful help.
Are you using SeeYou Windows app, SeeYou Mobile or SeeYou cloud?
How exactly are you creating a waypoint and how exactly are you looking at its elevation? If say you are looking at stuff in SeeYou Mobile then it may be you are getting confused with waypoint elevation, arrival height, etc.
Assuming you are using SeeYou Windows app as you move the cursor around you should see the elevation shown in the lower window border next to the cursor latitude and longitude, that changing display gives you an idea of the elevation data resolution. Elevation data is only useful within that resolution, if you are trying to pick super fine resolution elevation features it's not going to work. And pragmatically for anything important people usually hand-edit waypoint files, including elevation if needed.
If your SeeYou is not or has not been connected online I imagine it's possible that SeeYou has not downloaded the elevation data (I assume it's still downloading NASA elevation data, even that is a bit more hidden than it used to be).
Old February 2nd 20, 03:41 PM posted to rec.aviation.soaring
Tango Eight
I use https://viewer.nationalmap.gov/basic/ for accurate elevation data.
I used SeeYou 4 for a number of years and it worked pretty well in this regard. More recent versions... not so much. Ridge top waypoints created in SeeYou always have elevations lower than actual. I have seen errors as large as 600'.
Evan Ludeman / T8
Old February 2nd 20, 04:33 PM posted to rec.aviation.soaring
soaringjac
Just adding a couple local landmarks to my S100, mainly going to use to see if I have glide to the various waypoints. Not doing any XC or competition stuff. I might try some databases but it seems a bit overkill for now. I just want a couple local landmarks.
LXNAV 8000 OAT Incorrect Deming Gray Soaring 27 December 13th 18 10:05 PM
Seeking help regarding SeeYou waypoint management [email protected] Soaring 2 February 16th 18 01:19 AM
Warning: GPS data incorrect Cheetah236 Instrument Flight Rules 17 September 23rd 05 07:50 AM
SeeYou to LX7000 Waypoint Task Files Ken Kochanski (KK) Soaring 1 May 28th 05 12:22 AM
Incorrect Coastlines..Channel Islands....HELP !!!! Derek Simulators 0 March 23rd 05 11:50 PM
