glider canopy
Old February 10th 20, 06:36 PM posted to rec.aviation.soaring
Morris Carter
Default glider canopy
best way to trim a new canopy and best glue to use to attach to fiberglass
frame
Old February 10th 20, 09:30 PM posted to rec.aviation.soaring
Dan Marotta
Fidel, of course! :-D
frame
Dan, 5J
Old February 11th 20, 01:17 AM posted to rec.aviation.soaring
Bob Kuykendall
frame
I don't think that there is any universal "best" way, it depends on the materials, tools, and processes available to you at the time you need them.
In my shop we have a heated tent we can warm up to 80F for working acrylics.. We never cut, drill, or sand acrylic unless it is stabilized at at least 70F.
For cutting, we usually use a Harbor Freight 1" diamond rotary cutting disk in a Dremel-type moto tool.
https://www.harborfreight.com/diamon...-pk-69657.html
For bonding, we use an old-school epoxy mix, Epon 828 2:1 with Epikure 3140 hardener, filled with flox and a bit of cabocil. George Applebay once told me that diluents such as BGE (butyl glycidyl ether) in laminating epoxies can attack the acrylic, but I have no direct experience with that. I know several shops that use laminating resins for this so results clearly vary.
We mask off the bondline, sand it with 80 grit for tooth and degrease with isopropyl alcohol.
Old February 11th 20, 01:18 AM posted to rec.aviation.soaring
Bob Kuykendall
And, no, not sawzall.
Old February 11th 20, 02:52 AM posted to rec.aviation.soaring
Depends on how much material needs to be removed? If 1/4” or less needs to be removed, I use a 6” rotary hand sander with 60 grit disc.. If more material needs to be removed, I use a 3” carbide disk and then trim to final fit with disc sander. I sand the inside of the canopy that will be glued down, with 40 grit sandpaper to give the bond tooth! I use epoxy with chopped cotton to thicken the mix. I mask off both sides of the canopy and hold it in place with 3 or 4 bungee cords + small wooden blocks at areas that don’t want to lay down flat. Mask off the fuselage side, also..........a few minutes spent in preparation will save hours of re-do! Fill and sand until you get desired fit, then re-mask the canopy out about 1/8” for final painting. Recommend canopy be glued on with shop temperature about 65 degrees Fahrenheit, so that canopy will close on the ramp when it’s 100 + degrees and still won’t leak too much when the temperature drops below zero degrees, in that wave you stumbled upon!
Hope this helps,
JJ
Old February 11th 20, 03:25 AM posted to rec.aviation.soaring
Oops, forgot somethings........ slip 1/16” shims between canopy rail and fuselage, front and rear, then close and lock frame to fuselage! This gives the needed thermal range 0 to 100+F. I like to use a small guide post at the rear, so that I don't end up moving the gooped-up canopy. I paint on resin to the inside of the canopy and trawl- on cotton flox’ed goo on the frame. Schleicher uses a thin strip of foam tape to keep the goo from oozing out onto the inside of the canopy! This is definitely a TWO MAN JOB!
🥴 JJ
Old February 12th 20, 01:48 AM posted to rec.aviation.soaring
frame
The best way is to get some help from someone that has done this before.
What kind of glider and where are you located?
UH
Escaping glider on the ground with stuck canopy? Steve Koerner Soaring 27 May 21st 19 05:06 AM
Canopy Ejection and Canopy Lanyard Casey[_2_] Soaring 6 April 12th 16 06:09 PM
looking for damaged unflyable tandem glider fuselage and canopy touse as body for a 3 wheeld electric car. [email protected] Soaring 4 October 25th 15 04:18 PM
Where to get a glider canopy in the US Bob Kuykendall Soaring 0 September 4th 08 02:16 AM
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider [email protected] Soaring 5 November 20th 06 12:08 AM
