Shear Pins for Propellors?
Old April 1st 05, 04:32 AM
Rich Lemert
Default Shear Pins for Propellors?
Back when I was growing up on the farm, we used several powered
implements that received their power from the tractor through a power
take-off assembly. Somewhere on the device's power train, between the
PTO take-off and the "business end" of the apparatus, there was always
either a belt-drive or a coupling fitted with a "shear" pin. Both of
these systems were intended to protect that tractor (and the implement)
by failing if the implement bit off more than it could handle.
This morning, while driving past the airport on my way to work, the
thought occured to me that a shear pin could be used to protect airplane
engines (at least partially) from prop strikes. My understanding is that
the props on light singles (at least) are connected directly to the
engine's drive shaft.
Recognizing that this issue is driven as much by regulation as by
anything, I'm wondering if there would be any benefit to using shear
pins in these systems. Would it reduce the need for a complete (or
partial) tear-down after a prop strike? Would there be any benefit for
more complex propeller arrangements?
Any thoughts?
Rich Lemert
Newbie question on trailering Setup joe Soaring 11 December 27th 04 12:10 AM
sound of wind shear Dan Jacobson General Aviation 2 May 12th 04 12:43 AM
IPAQ Wiring - which pins are used Michael Soaring 9 March 15th 04 09:48 PM
Amazing Wind Shear Today Jay Honeck Piloting 25 December 3rd 03 11:23 PM
taper pins Ernest Christley Home Built 4 September 12th 03 04:15 AM
