Meter Problems
Old April 3rd 05, 03:58 PM
Robert A. Barker
Default Meter Problems
All:
I have a 1966 C150 with a Continental 200 engine.
Before I bought the plane,the owner had the generator
removed and replaced with an alternator.Part of that installation included a
circular cluster gage that has a voltmeter,ammeter,cht meter and egt meter.
During my recent run-up I switched the alternator field
off and realized the voltmeter was reading app.3 volts and the ammeter sat
at zero.
Further tests show the voltmeter reads app. 3 volts
when the master is on and zero when the master is off.
I connected a voltmeter to a cigerette lighter plug and it
read 11.9 volts.With the engine running the voltage increases to 14.2.This
shows the alternator is doing it's
thing but the gages are not.Connecting a milliamp meter
across the shunt terminals definately shows a differnt reading when radios
or any lights are turned on or off.
It would appear the meters in the plane have gone west, but it seems too
much of a coincedence that both
would crap out at the same time.Especially since the volt meter reads
something (not correct) while the ammeter
doesn't respond at all.
Anyone had any experience with this sort of thing?My
next step is to cut apart the nice neat wiring harness and try to trace all
wires looking for bad connections or removing the cluster gage and bench
testing.Both of these are a major pain in the a**.I am looking for a simple
solution but I am aware such a thing may exist only in my
sometimes vivid imagination.
Any and all suggestions greatly appreciated.
Bob Barker N8749S
Old April 3rd 05, 05:18 PM
Stealth Pilot
On Sun, 3 Apr 2005 09:58:55 -0400, "Robert A. Barker"
All:
at zero.
Bob Barker N8749S
the simplest solution would be to mark them unserviceable and keep
flying.
Stealth ( but I bet you wont do that :-) ) Pilot
Old April 4th 05, 06:07 AM
John_F
You most likely have a high resistance in the wiring to one of the
shunt taps. This should be findable with a ohm meter. I will bet it
is a butt splice made with a cheap crimper. Get a T&B IU style
crimping tool.
John
All:
at zero.
Bob Barker N8749S
Mooney Engine Problems in Flight Paul Smedshammer Piloting 45 December 18th 04 10:40 AM
Uvalde Open and 18 Meter 2ond practice day.#711 reporting TomnKeyLargo Soaring 0 August 9th 04 05:58 PM
Radio Shack SWR meter Paul Lee Home Built 6 June 2nd 04 05:42 AM
F22 Problems Paul F Austin Military Aviation 9 February 5th 04 03:27 AM
Kestral 1000 Wind Speed Meter NEW IN BOX Cecil E. Chapman Products 0 November 7th 03 07:56 PM
