Anyone else notice that after updating to Condor 2.1.1 the ASG-29Es trimer is not functional? While other aircraft still have functional trimmers.
On Sunday, May 3, 2020 at 2:02:40 PM UTC-8, Jonathan St. Cloud wrote:
Anyone else notice that after updating to Condor 2.1.1 the ASG-29Es trimer is not functional? While other aircraft still have functional trimmers. Just a guess.. In the settings there is a box to check or uncheck "use stick trim" Im not a power user, however this solved the problem on another glider in the program. |
On Sunday, May 3, 2020 at 5:19:26 PM UTC-7, wrote:
On Sunday, May 3, 2020 at 2:02:40 PM UTC-8, Jonathan St. Cloud wrote: Anyone else notice that after updating to Condor 2.1.1 the ASG-29Es trimer is not functional? While other aircraft still have functional trimmers. Just a guess.. In the settings there is a box to check or uncheck "use stick trim" Im not a power user, however this solved the problem on another glider in the program. I will look at that, however the trim works just fine on the 2.1.1 for the JS1C-21 and on version 2.0.6 the trim worked fine for the all gliders. Will report back |
On Monday, May 4, 2020 at 10:24:22 AM UTC-7, Jonathan St. Cloud wrote:
On Sunday, May 3, 2020 at 5:19:26 PM UTC-7, wrote: On Sunday, May 3, 2020 at 2:02:40 PM UTC-8, Jonathan St. Cloud wrote: Anyone else notice that after updating to Condor 2.1.1 the ASG-29Es trimer is not functional? While other aircraft still have functional trimmers. Just a guess.. In the settings there is a box to check or uncheck "use stick trim" Im not a power user, however this solved the problem on another glider in the program. I will look at that, however the trim works just fine on the 2.1.1 for the JS1C-21 and on version 2.0.6 the trim worked fine for the all gliders. Will report back Interesting; I have no problem with the ASG 29es trim (I use the trigger on the Logetch control stick) but no trim at all on the JS-1C |
The trim doesn't work on my LS-8 Neo. It worked on several gliders before the latest update but the LS-8 is a recent addition. I'll check other gliders next time.
Yes, I've configured the input for the trimmer and Condor recognizes the slider control. But it doesn't work while flying. Chip Bearden JB |
On Monday, May 4, 2020 at 8:29:13 PM UTC-4, wrote:
The trim doesn't work on my LS-8 Neo. It worked on several gliders before the latest update but the LS-8 is a recent addition. I'll check other gliders next time. Yes, I've configured the input for the trimmer and Condor recognizes the slider control. But it doesn't work while flying. Chip Bearden JB Works on my Condor LS8 Neo. I have deactivated stick trim and use the same trim on all gliders in Condor so I can't forget. |
On Monday, May 4, 2020 at 8:45:22 PM UTC-5, Dan Daly wrote:
On Monday, May 4, 2020 at 8:29:13 PM UTC-4, wrote: The trim doesn't work on my LS-8 Neo. It worked on several gliders before the latest update but the LS-8 is a recent addition. I'll check other gliders next time. Yes, I've configured the input for the trimmer and Condor recognizes the slider control. But it doesn't work while flying. Chip Bearden JB Works on my Condor LS8 Neo. I have deactivated stick trim and use the same trim on all gliders in Condor so I can't forget. I've had trouble with the trim in my LS-4 in Condor 2 also but just thought it was the "loose nut behind the stick" maybe not. I'll try deactivating the stick trim to see if that helps. |
On Monday, May 4, 2020 at 12:02:40 AM UTC+2, Jonathan St. Cloud wrote:
Anyone else notice that after updating to Condor 2.1.1 the ASG-29Es trimer is not functional? While other aircraft still have functional trimmers. Guys, There's nothing wrong with the trim. Condor simulates the trim system used in each glider. Some have lever, some have stick trim and you need to know which they are and map a control suitable for each type. If you don't want to have that, we have provided an override as mentioned in this thread to let you disable stick trim and use lever in all gliders. |
Some have lever, some have stick trim and you need to know which they are and map a control suitable for each type. What is "stick trim"? Don't all trim mechanisms control the position of the stick? |
Some trims are a lever on the cockpit side, some are a lever alongside the stick...usually have to map a different control in any simulator for the function to work.....thus, different mapping for different ships...similar ships, keyboard mapping to work....change trim type, different mapping.
| Thread Tools | |
| Display Modes | |
| Curtiss B-2 Condor pics 3 [2/8] - Eastern Air Transport CO Condor.jpg (1/1) | Miloch | Aviation Photos | 0 | August 30th 18 01:26 PM |
| Curtiss B-2 Condor pics [01/11] - B-2 civilian version Model 53 Condor 18.jpg (1/1) | Miloch | Aviation Photos | 0 | August 30th 18 01:20 PM |
| Curtiss T-32 Condor II pics 1 [02/11] - 1930s-passengers-boarding-american-airlines-condor-biplane-airplane-AAMYTR.jpg (1/1) | Miloch | Aviation Photos | 0 | November 17th 17 03:38 PM |
| Curtiss T-32 Condor II pics 1 [01/11] - 1007-condor.jpg (1/1) | Miloch | Aviation Photos | 0 | November 17th 17 03:38 PM |
| Condor Thanksgiving and Condor Christmas Contests | [email protected] | Soaring | 0 | October 22nd 12 04:33 PM |
