KGARS - Kiting Glider Automatic Relase System
Old May 19th 20, 03:50 AM posted to rec.aviation.soaring
Karl Striedieck[_2_]
Default KGARS - Kiting Glider Automatic Relase System
On Friday, May 15, 2020 at 8:38:49 AM UTC-4, wrote:
KGARS – Kiting Glider Automatic Release System
About 10 years ago I assembled an auto tow hitch that utilized a TOST release and a small pneumatic cylinder. With a small air bottle at ~100 psi and a solenoid valve and a switch I was able to put the switch in the car for the driver in case there was a need to release the cable. Worked fine and opened in a fraction of a second. Links to a picture and old .AVI video below…
Leaving the concerns of certification, 337s, etc. towards the end of the project, I think a similar system could be designed that would detect an “beyond normal” aft stick input of the towpilot and automatically release the towplane end of the towrope. An aft stick input is probably the first input that occurs, intuitively and with minimal delay, in a upset event.
A simple pitot/static pressure switch could prevent the release from opening if the towplane was on the ground.
I suspect that installing the actuator in the cockpit in parallel with the manual release would probably makes the most sense. Keeping the manual release preserves the ability of the towpilot to release in case of failure or if things are going poorly for other reasons. Installing a “dump” switch could also afford the pilot the option to use the actuator if he/she so chose.
Supplying pressure for the system could be as simple as utilizing a 12g CO2 cartridge. The stroke volume of the cylinder I used was small and keeping a few spare cartridges in the towplane would make refilling cheap and convenient if needed.
Given the wealth of expertise of this group, I’m certain a system could be designed and FAA paperwork completed if there was a group willing to work on this type of project.
While admonishing glider pilots to release if they lose sight of the towplane is valid, the kiting event I saw recently occurred due to aft seat back movement and in the first 1-2 seconds there was no way the pilot could get to the relase. Fortunatly, that event ended as well as could be hoped for. Something that’s automatic and very fast acting would probably enhance towpilot safety.
With all due respect,
Mark
http://daziv.com/kgars/hitch.jpg
http://daziv.com/kgars/release.avi
The aerodynamics of a towplane in a kiting glider situation Tom BravoMike Soaring 42 May 23rd 20 03:42 AM
KGARS - Kiting Glider Automatic Relase System Wit Wisniewski Soaring 2 May 19th 20 02:04 AM
KGARS - Kiting Glider Automatic Relase System AS Soaring 0 May 15th 20 03:46 PM
F-35 Automatic Ground Collision Avoidance System 37db18205c03cc1618cc9c662a08d380.jpg 115 (1/1) J3[_2_] Aviation Photos 1 July 26th 19 03:12 PM
Glider Oxygen System Presentation OHM Ω http://aviation.derosaweb.net Soaring 4 May 3rd 18 04:48 PM
