Not Gliding, But Flying, Sorta....
Old May 22nd 20, 08:03 PM posted to rec.aviation.soaring
Dan Marotta
Default Not Gliding, But Flying, Sorta....
I'm in the country south of Blum, TX where I've just completed my new
gyro plane kit.Â* Unfortunately, the as delivered brake master cylinder
was faulty, so I've had to tie the aircraft down for engine run tests.Â*
Otherwise, everything worked perfectly except for a very small coolant
leak which was fixed by tightening a clamp.
I just got back from a custom motorcycle shop where I found a
replacement o-ring for the brake cylinder and hope to get the brakes
working today.Â* Failing that, I'm waiting for shipping from Poland for a
warranty replacement.
As soon as I get the brakes working, I can try spinning up the rotor
system and then taxi around until I'm satisfied that the engine
installation is airworthy.Â* I'll then schedule an airworthiness
inspection which I understand takes at least 2 1/5 weeks to get a DAR on
site.Â* The FAA is still on lock down orders.Â* So, I'll probably head
home within the next couple of days until the inspection can be scheduled.
Maybe I'll fly my glider when I get home.Â* There.Â* Now it's soaring
related. :-D
Dan, 5J
OBTW, my N-number ends in 5J, just like on my Stemme.
Old May 22nd 20, 08:14 PM posted to rec.aviation.soaring
home within the next couple of days until the inspection can be scheduled..
related. :-D
Dan, 5J
Cool. Let us know how you like when it is up and spinning.
Old May 23rd 20, 01:40 AM posted to rec.aviation.soaring
Dan Marotta
I've flown one that is similar and loved it.Â* Buzzing around at and
below 500' AGL gives a whole new perspective to flying.
related. :-D
Dan, 5J
Dan, 5J
Winter flying at SOSA Gliding Club Luke Szczepaniak Soaring 2 January 27th 15 07:00 PM
OT-Sorta Garmin 296 Auto Nav Kit Terry Owning 4 August 2nd 06 01:40 AM
Capt. Al Haynes sorta OT. James Blakely Instrument Flight Rules 122 January 21st 04 12:23 AM
Capt. Al Haynes sorta OT. James Blakely Owning 122 January 21st 04 12:23 AM
Sorta a glider, sorta a dirigible Stewart Kissel Soaring 9 January 7th 04 05:47 AM
