Having carefully analyzed my flight requirements and plans for the next
five years or so, I've decided to take the plunge, probably on a C-172L that I've been looking at. The fixed costs are right about the amount of what I've been spending renting (actually a little lower) and I'm about ready to schedule the pre-buy. I live in Oklahoma so density altitude is noticeable, but not necessarily a concern Does anyone have some historical data of their own experiences (both good and bad) with C-172L's? Would you consider one as a practical first aircraft for a relatively new pilot looking to get his instrument ticket and build hours? Don |
![]() wrote in message ups.com... Having carefully analyzed my flight requirements and plans for the next five years or so, I've decided to take the plunge, probably on a C-172L that I've been looking at. The fixed costs are right about the amount of what I've been spending renting (actually a little lower) and I'm about ready to schedule the pre-buy. I live in Oklahoma so density altitude is noticeable, but not necessarily a concern Does anyone have some historical data of their own experiences (both good and bad) with C-172L's? Would you consider one as a practical first aircraft for a relatively new pilot looking to get his instrument ticket and build hours? Don Seems like you have analyzed it well. My opinion is that the C172 is an excellent AC for building hours and instrument training. Docile and slow. Stable IFR handling. Good 2 place AC up to DA 10,000 ft. Good 4 place AC up to DA 7-8,000 feet. Can be flown much higher with appropriate precautions. In my experience the fixed prop resulted in more pilot fatique on long flights (4+ hours). If it fits your requirements I believe the cost/benefit ratio of the 172 is better than either the 152 or 182. As you get more experience, start mountain flying or need to carry 4 adults and baggage regularly then the move up to a 182 might make sense. The 182 has significantly higher operating costs than the 172. Just my opinion Best of Luck Howard C182P |
![]() "Howard Nelson" wrote in message m... fatique oops. fatique = fatigue howard |
Howard Nelson wrote:
: In my experience the fixed prop resulted in more pilot fatique on long : flights (4+ hours). If it fits your requirements I believe the cost/benefit What do you mean by that? If anything, I'd say a fixed-pitch prop reduces workload (especially in IMC) because you can hear small pitch changes as an RPM change. Just curious what you meant, -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() wrote in message ... Howard Nelson wrote: : In my experience the fixed prop resulted in more pilot fatique on long : flights (4+ hours). If it fits your requirements I believe the cost/benefit What do you mean by that? If anything, I'd say a fixed-pitch prop reduces workload (especially in IMC) because you can hear small pitch changes as an RPM change. Just curious what you meant, -Cory Not work load and not IFR, just physical fatigue. I had always presumed it was from the constant RPM changes and vibrations transmitted back to the cockpit. I have very few hours in 172 with CS prop. Most hours in C177RG and C182. I may not be comparing apples to apples. I just felt more physically tired after C172 cross country flights and chalked it up to a greater level of noise and vibration. Howard |
: Not work load and not IFR, just physical fatigue. I had always presumed it : was from the constant RPM changes and vibrations transmitted back to the : cockpit. I have very few hours in 172 with CS prop. Most hours in C177RG and : C182. I may not be comparing apples to apples. I just felt more physically : tired after C172 cross country flights and chalked it up to a greater level : of noise and vibration. : Howard OK, I see what you mean, but I'd venture to say that CS vs. FP prop doesn't inherently mean more or less vibration. If they're both balanced properly, they should be basically the same. Comparing it to a 182 is much more likely 6 cylinders vs. 4. Also, three-bladed vs. two-bladed makes a difference in the harmonics produced/felt. If your 172 was old enough to have the O-300 Cont in it, it's a moot point, but with a 4-banger Lycoming, it's got lots of rattle. Comparing my O-360 FP Lyc Cherokee to a friend's O-540 CS Commanche is night and day for vibration. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() wrote in message ... Howard Nelson wrote: : Not work load and not IFR, just physical fatigue. I had always presumed it : was from the constant RPM changes and vibrations transmitted back to the : cockpit. I have very few hours in 172 with CS prop. Most hours in C177RG and : C182. I may not be comparing apples to apples. I just felt more physically : tired after C172 cross country flights and chalked it up to a greater level : of noise and vibration. : Howard OK, I see what you mean, but I'd venture to say that CS vs. FP prop doesn't inherently mean more or less vibration. If they're both balanced properly, they should be basically the same. Comparing it to a 182 is much more likely 6 cylinders vs. 4. Also, three-bladed vs. two-bladed makes a difference in the harmonics produced/felt. If your 172 was old enough to have the O-300 Cont in it, it's a moot point, but with a 4-banger Lycoming, it's got lots of rattle. Comparing my O-360 FP Lyc Cherokee to a friend's O-540 CS Commanche is night and day for vibration. -Cory Probably is 4 vs 6. I had a chance to fly an older 6 cylinder straight tail 172 and loved how smooth the engine was. Howard |
![]() Howard Nelson wrote: snip I just felt more physically tired after C172 cross country flights and chalked it up to a greater level of noise and vibration. That's easy. Compared to the 182 and 177RG, you were spending 50% more time in the air to get to the same place :-))) John Galban=====N4BQ (PA28-180) |
I've had an M model (1975) for the last 29 years.
Watch the front end of the engine for vibration related cracking of the tin work and cooling baffles, the alternator assembly and the alternator mount. Nose mounted landing lites have a history of quickly burning out. I sprayed some silicon spray on the black baffle material to allow it to slip easier within the cowl & got rid of this problem. The cowl mounts will crack in time, & the muffler flame tubes disintegrate every 450 hrs like clockwork. Lycoming engines are hypersensitive to cold starts because of the upstairs camshaft. I suggest preheating the oil if it is below 40 degF. Mine has run great for 15 years on mostly UL autofuel & am now at 1700 hrs TTSN with 35 hrs/qt oil consumption. It has the full flow filter option though. Be sure to check the stabilizer spar center section for bucking caused by mishandling on the ground. If you have McCauley wheels be aware that they have a magnesium center section with steel flanges & must be treated with care - i. e. proper bolt torque on assembly por the threads can be stripped. Check the left rear flap skin for possible small cracks at the trailing edge. The 172 has no vices. It can handle hot temps, short fields, gross weights, hi altitudes etc - it just can't handle combinations. Structurally it is solid, and the engine if treated right, is bullet proof. |
Don,
We run three 172Ls in traffic watch. They stay plugged into heaters whenever not in use. They are docile, reliable and easy to fly. They each get 20-30 hours a week use. This is good thing since we have a 200 foot window between being to low (1000 AGL) and to high (floor of Class B). Michelle wrote: Having carefully analyzed my flight requirements and plans for the next five years or so, I've decided to take the plunge, probably on a C-172L that I've been looking at. The fixed costs are right about the amount of what I've been spending renting (actually a little lower) and I'm about ready to schedule the pre-buy. I live in Oklahoma so density altitude is noticeable, but not necessarily a concern Does anyone have some historical data of their own experiences (both good and bad) with C-172L's? Would you consider one as a practical first aircraft for a relatively new pilot looking to get his instrument ticket and build hours? Don |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
