SH airbrakes hardware
Old June 13th 20, 09:48 PM posted to rec.aviation.soaring
Default SH airbrakes hardware
So, pardon me for not knowing proper terminology... this concerns the bolt/spring/elastic stop nut assemblies that keep the flexible cap strip on the rigid spoiler. Some of this hardware was showing corrosion, but when attempting to remove for replacement or cleaning, the head of the bolt (stud?) seems to have torqued free from where it is glassed in place. Also, there is an L- shaped bracket at the outboard, aft end of the spoilers - purpose? One of them seems rather loose. It is secured by the same bolt assembly. Don't want to tighten in case bolt breaks free like the other. I would post a photo but don't see how.
std cirrus airbrakes [email protected] Soaring 2 September 10th 16 02:24 AM
Flaps VS Airbrakes/Spoilers Walt Connelly Soaring 24 August 18th 11 12:05 PM
Full-span flaperons as airbrakes? Bret Soaring 21 March 20th 10 11:39 PM
Spoilers or Airbrakes - Whats in a name? ContestID67 Soaring 29 May 20th 08 06:21 PM
Airbrakes Pop Out at 115 kts ContestID67 Soaring 13 May 10th 05 02:50 PM
