Which Gel Coat for light repairs on S.H.
Old June 15th 20, 04:38 AM posted to rec.aviation.soaring
Mike N.
Default Which Gel Coat for light repairs on S.H.
I'd like to do some light repairs on my S.H. Ventus Ct. With original finish in very good condition.
I just want to clean up a couple of areas of light hanger rash. Some light dings and chips.
I've read several articles on Gel Coat repairs, but would like to get a good idea on the best gel coat to order for this type of work.
Thank you,
Mike N.
Old June 15th 20, 02:15 PM posted to rec.aviation.soaring
KG[_2_]
Thank you,
Mike N.http://www.simteccoatings.com/Productlist.ivnu
Old June 15th 20, 02:25 PM posted to rec.aviation.soaring
Thank you,
Order 2481 and catalyst from Simtec.
UH
Old June 15th 20, 03:20 PM posted to rec.aviation.soaring
UH
Interesting, the instructions say before applying to wipe down with
slow evaporating lacquer thinner or IPA (Isopropyl Alcohol).
instead of acetone.
Old June 15th 20, 04:46 PM posted to rec.aviation.soaring
UH
instead of acetone.
Water and very fine sandpaper will get contaminants off and proved tooth for new material.
Every solvent I've tried smears contaminants and provides no assurance of a good surface to bond to.
Just one guy's experience.
UH
Old June 16th 20, 12:18 AM posted to rec.aviation.soaring
Dan Marotta
Wipe down with IPA???Â* I'd rather drink it! :-D
UH
instead of acetone.
Dan, 5J
Old June 16th 20, 12:57 AM posted to rec.aviation.soaring
If your near SE Georgia USA I have everything you need left over from refinishing XF I’ll give you for free. Pickup only though!
Lane Bush
Old June 16th 20, 01:02 AM posted to rec.aviation.soaring
IPA is fine as beer, (India Pale Ale) but as IPA (isopropyl alcohol) it isn't. The label says, "For external use only. If taken internally, serious gastric disturbances will result."
But then again, eight or ten India Pale Ales will also lead to serious gastric disturbances.
Old June 16th 20, 02:24 AM posted to rec.aviation.soaring
Mike N.
Thanks, I am in Utah.
How about I pay for shipping?
Old June 19th 20, 05:34 AM posted to rec.aviation.soaring
Agree on the Simtec 2781. The will include a flex additive to the paint if requested if painting bendy bits.
gel coat BobWa43 Soaring 54 November 1st 19 09:20 PM
Gel coat removal - is this okay?!? Kevin Christner Soaring 13 July 10th 15 04:44 PM
Gel coat inspection Matt Keast[_2_] Soaring 12 October 26th 07 10:14 PM
Gel Coat Question Gary Emerson Soaring 2 September 12th 07 12:56 PM
Gel Coat for Dummies Ray Lovinggood Soaring 2 December 12th 04 09:15 PM
