Instructions for BFG Loran C
Old April 17th 05, 07:50 PM
Mike W.
Default Instructions for BFG Loran C
Anybody own/use one of these regularly? Two of the planes in the fleet at my
flying club have them, no manuals. I had it demonstrated once, but of course
had a month or two when I didn't use it so forgot. If available online
somwhere would be awesome.
Anybody?
Hello, my name is Mike, and I am an airplane addict....
Old April 17th 05, 10:14 PM
john smith
Which model?
Anybody?
Old April 17th 05, 10:39 PM
Mike W.
Hmmm not sure, I don't have a digital cam or I would post a pic. I don't
remember seeing any numbers on the front anywhere. I wish I knew more
specifics.
Layout is like this. Five push buttons across the bottom, on the right is a
rotary switch for flight plan, position, nav. etc. On same control is a
smaller knob to allow for selection of flight plan, inputting identifiers,
etc. Has orange display.
"john smith" wrote in message
Which model?
Old April 17th 05, 10:51 PM
john smith
If it is the BFG that was originally the Foster AirData, I have a manual
I can copy.
specifics.
Old April 18th 05, 03:18 AM
Mike W.
Thanks for the responses, John. It looks an awful lot this unit pictured
here.
http://www.controller.com/listings/f...D2B35015679115
Listed as an BFG F14 Loran-C.
I can copy.
Old April 18th 05, 04:27 AM
George Patterson
I had one in my Maule. I no longer have the manual, and I never used all of the
features, but here's what I remember. We'll run through the big knob first.
The GRI position allows you to select the LORAN chain you want. If you take it
several hundred miles, you'll probably get out of range of the chain you're
using. You can use this feature to change chains. Since you don't have the
manual, just let it figure out the situation automatically. This takes five or
ten minutes.
The Pos feature tells you what where you are. The default is distance and radial
from the closest Navaid. Use the Page button to change the screen. You can get
it to report Lat/Long this way.
The Nav feature was the biggie for me. I generally just went directly to the
next waypoint. To do that, turn to Nav. It will display the last destination
(we'll use "K3N6" as an example). The screen will say "Direct To? K3N6." If
that's what you want to do, hit the Entr button.
If you want to enter a new destination, hit the Msg button. A "destination"
screen will appear with the cursor blinking just to the right of the letter "K."
If you're going to an airport in the U.S., turn the little knob until the letter
you want is in that position. If you're going to an intersection, hit the button
beside the left arrow to move back and overwrite the "K." Once the first letter
is entered, hit the button beside the right arrow to move to the next position.
When you get the ID entered, hit the Entr botton. Assuming the Id is in the
database, the screen will then display the course and distance to the station,
along with a little CDI. Using the Page button will get you several other
screens; one gives you track info, another ETE, etc..
The FPL feature allows you to enter and retrieve flight plans. I never used
this, but I recall that waypoints are entered using the same method as is used
to enter destinations in the Nav feature. You can enter waypoints either by
inserting them in between your departure point and your destination or by adding
waypoints in a chain until the destination is entered. This is best done by
taking the LORAN home and plugging it into a powerpack (which is why I never
used it).
The Wpt feature allows you to enter waypoints. BFG dropped most small airports
from the database about 1994, so you will get real good at this feature if you
have a recent database. I don't remember the exact procedure, but you need to
make up an Id and know the latitude and longitude of the waypoint. If you're
entering data for an airport BFG dropped, you can use the real airport Id. The
database cartridge is a small box plugged in the right rear of the unit. It
should have the last update date on it. If this is 1995 or later, the unit will
be of very limited use.
The Aux feature gives you the nearest ten airports. IIRC, the Page button will
retrieve frequency info and other data about the airport currently displayed on
the screen. This may also be true (or may only be true) for the Wpt feature.
Play around with it.
Now. If you turn the thing on and the GRI page doesn't give you any useful info,
the internal battery is probably dead. This is soldered into the mother board.
You can get one at any good electronic store (Rat Shack will not have them). It
looks something like the capacitor in an old automobile distributor.
George Patterson
There's plenty of room for all of God's creatures. Right next to the
mashed potatoes.
Old April 18th 05, 05:19 AM
Mike W.
Thanks George. Sounds like you are talking about the same unit. I will print
this out and take it with me next time I go to the airport.
"George Patterson" wrote in message
news:BWE8e.25581$1p4.24561@trndny06...
Mike W. wrote:
SNIP
George Patterson
mashed potatoes.
LORAN antenna difference? JFLEISC Home Built 6 December 24th 04 11:10 PM
RUMSFELD GAVE INSTRUCTIONS FOR TORTURE AT ABU GHRAIB MORRIS434 Military Aviation 1 July 3rd 04 12:41 AM
RUMSFELD GAVE INSTRUCTIONS FOR TORTURE AT ABU GHRAIB MORRIS434 Naval Aviation 0 July 2nd 04 03:23 PM
Flybuddy Loran Henry Kisor Owning 5 September 18th 03 11:47 PM
Big News -- WAAS GPS is Operational for IFR Lockheed employee Instrument Flight Rules 87 July 30th 03 03:08 AM
