Is teflon safe to use under mylar tape wing seals?
Old July 10th 20, 04:46 AM posted to rec.aviation.soaring
Tom BravoMike
Default Is teflon safe to use under mylar tape wing seals?
I have applied some teflon spray with a brush into the canopy sliding window rails with good result. Now I'm wondering whether I could use it in the same way under the mylar tape on the wings to reduce friction and ease forces on the ailerons. Any thoughts if and how it reacts with gelcoat/glass fiber/carbon fiber structure? I am cautioned by the common knowledge about negative influence silicon may have on composites. Is there any similarity?
Thanks in advance for sharing your experience, if any.
Tom BravoMike
Teflon tape attaching JohnO[_2_] Soaring 3 June 19th 18 10:40 PM
Teflon tape [email protected] Owning 7 March 9th 08 04:44 AM
Teflon gap seal tape... Marc Ramsey Soaring 10 April 3rd 05 05:35 PM
mylar seals wing to flap/ Aileron culverflyer Soaring 2 May 5th 04 03:52 PM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 04:46 PM
