Anybody out there got a design for a battery powered tug??
TIA Paul |
How about a gas powered? fella in my chapter took a old belt driven
snowblower, removed the belt, and filled the auger/chute area with 60# of concrete for traction. Now he's got a tug for about 60 bucks. ![]() John |
Hi John
Very good idea, only problem we don't have snow blowers in the UK, but thanks for the input I'll have a look at some other agricultural power driven units. I am still real interested in an battery powered jobber if anybody has created one. Paul "John T" wrote in message ... How about a gas powered? fella in my chapter took a old belt driven snowblower, removed the belt, and filled the auger/chute area with 60# of concrete for traction. Now he's got a tug for about 60 bucks. ![]() John |
planenutz wrote:
Very good idea, only problem we don't have snow blowers in the UK, but thanks for the input I'll have a look at some other agricultural power driven units. I am still real interested in an battery powered jobber if anybody has created one. Didn't Kitplanes (maybe another mag) have a recent article on a cordless drill creation? I think the details were sketchy though, not a Jim Weir production forsure. I might be wrong but I believe it used the remains from a weedeater powered garden tiller... |
Darrel Toepfer wrote:
planenutz wrote: Very good idea, only problem we don't have snow blowers in the UK, but thanks for the input I'll have a look at some other agricultural power driven units. I am still real interested in an battery powered jobber if anybody has created one. Didn't Kitplanes (maybe another mag) have a recent article on a cordless drill creation? I think the details were sketchy though, not a Jim Weir production forsure. I might be wrong but I believe it used the remains from a weedeater powered garden tiller... The one in Kitplanes (from a month or two ago) was based on a Ford truck wiper motor, a Harbor Freight rubber tire, some scavenged bicycle gears and chain, a small sealed lead-acid battery and a Volvo window switch... but mainly it was just about ideas to cobble something together more than "plans". It all comes down to the fact that if someone's a good scavenger and knows how to weld they can build anything. Mark "occasionally it'll even fly" Hickey |
planenutz wrote: Hi John Very good idea, only problem we don't have snow blowers in the UK, but thanks for the input I'll have a look at some other agricultural power driven units. I am still real interested in an battery powered jobber if anybody has created one. Ye gods! some heavy duty batteries, a high-torque, low-RPM, gear-motor, and an on-off switch. Look around for _anything_ electrically operated that is 'self propelled'. At one extreme, an electric golf cart. At another, I believe there was a U.K. TV show, on which the U.S. "Robot Wars" was based. *LOTS* of possibilities there. For petrol-powered, consider a self-propelled lawn mower. Maybe the big-brother, "riding" variety, sometimes called a 'lawn tractor'. Or a "roto-tiller", used for plowing small gardens. remove the tines, put on tyres, and voila! Lastly, how about an old Morris "Mini" ? giggle |
Robert Bonomi wrote:
In article , planenutz wrote: Hi John Very good idea, only problem we don't have snow blowers in the UK, but thanks for the input I'll have a look at some other agricultural power driven units. I am still real interested in an battery powered jobber if anybody has created one. I was told once about a guy who built himself a little cart powered by a car starter motor. IIRC, he had two wires from the battery to the motor... using one wire gave low power... if he wanted high power he connected the second wire up in parallel. Frank |
![]() "Frank van der Hulst" wrote I was told once about a guy who built himself a little cart powered by a car starter motor. IIRC, he had two wires from the battery to the motor... using one wire gave low power... if he wanted high power he connected the second wire up in parallel. This would work, if it were not used at high power for very long, or even at low power, not all that long. I'm guessing that the low power wire was small enough to act as a resistor. It would get very hot. Better off to use a larger wire, then a short length of smaller, uninsulated wire for the resistor, where the extreme heat would not do any harm. Starter motors have no good way to get rid of the heat they generate, because they have no cooling fan. In cars, they only operate for short bursts, so the heat buildup is not much of an issue. They rely on the thermal mass of the case, but that does not help the armature keep cool very well. I saw a plan for a winch, for launching RC gliders, that used a starter motor. They had attached a large set of cooling fins all of the way around the outside of the case. It helped, but because of the armature issue, it still could not be operated very many times before it had to sit and cool down. -- Jim in NC |
![]() "planenutz" wrote in message ... Anybody out there got a design for a battery powered tug?? TIA Paul I could easily see a fork to hold a rubber tire, with the towbar welded on, as to give a lever to pull against the handle to make force to keep the drive tire on the ground. Use a 12 to 18 volt drill, with a low speed gearbox, and chuck up a small tire with an axle to press on the drive tire. -- Jim in NC |
Morgans wrote:
"planenutz" wrote in message ... Anybody out there got a design for a battery powered tug?? TIA Paul I could easily see a fork to hold a rubber tire, with the towbar welded on, as to give a lever to pull against the handle to make force to keep the drive tire on the ground. Use a 12 to 18 volt drill, with a low speed gearbox, and chuck up a small tire with an axle to press on the drive tire. There's a commercially produced product built as you describe but using a starter motor & chain drive to the wheel with 12v car battery as power source. There's one in my hangar right now. IIRC, it's called a 'Taildragger Dragger'. Charlie |
