TFRs on Google Earth?
Old September 12th 20, 05:13 PM posted to rec.aviation.soaring
jp
Default TFRs on Google Earth?
Is there a way - an easy way hopefully - to have TFRs display on Google Earth?
Old September 12th 20, 05:36 PM posted to rec.aviation.soaring
jp
Answering my own question: I plotted the corners of the Bobcat TFR on Google Earth and then connected the corners with a red line. Not quick but did the job.
Old September 12th 20, 06:26 PM posted to rec.aviation.soaring
Ron Gleason
I have used this GE plugin for a number of years with good results http://www.2ld.de/tfr2kml/
Old September 12th 20, 06:28 PM posted to rec.aviation.soaring
GliderCZ
SkyVector (online charts and flight planning website) has TFRs plotted in a timely manner. No user action required.
skyvector.com
Other formats found he http://soaringdata.info/tfrs/tfrs.php, including .kml for Google Earth.
Old September 12th 20, 08:19 PM posted to rec.aviation.soaring
jp
skyvector.com
Yes, I use skyvector and like it a lot. For this particular case I was looking for more ground detail that the sectional chart in skyvector provides.
Old September 13th 20, 12:20 AM posted to rec.aviation.soaring
2KA
As GliderCZ pointed out, my website at http://www.soaringdata.info does this.
- Select the TFRs tab
- Follow the link to the query form
- Enter a center airport and a radius to define the area of interest
- select Google Earth KML format for the output
.... and download a KML file containing all the TFRs in the area that can be opened in Google Earth.
It is all free and freely redistributable.
Lynn Alley
"2KA"
Old September 13th 20, 04:45 PM posted to rec.aviation.soaring
Scott Manley[_3_]
The Google Earth app I have installed on my iMac has a ool that enables drawing circles of known radius. I used the drawing tool to put concentric glider rings around my home airport and designate Class C & D airspace nearby.. Send a message to smanley at wisc dot edu and I'll reply with an image attachment.
Old September 13th 20, 05:40 PM posted to rec.aviation.soaring
2KA
Scott :
The airspace depiction is another thing that SoaringData.Info will do for you. Just download allusa.kml on the airspace tab at http://soaringdata.info. Or you can just check the "Add ATC-controlled airpspace" box when you do the TFR query I described above.
Lynn
Old September 13th 20, 04:48 PM posted to rec.aviation.soaring
Scott Manley[_3_]
Another option would be to use an image capture function to take a picture of the Google Earth screen, then import the image into a Microsoft Office app (Excel or Word) and use the MS drawing tools to add in the TFR. Then capture that image.
Google Earth Pro changes [email protected] Soaring 4 May 8th 20 12:17 AM
V2 Google Earth Pro changes [email protected] Soaring 0 May 7th 20 08:33 PM
Saw This On Google Earth John[_1_] Naval Aviation 3 January 27th 08 12:25 AM
Google Earth Frank Whiteley Soaring 3 November 16th 07 12:36 AM
Google Earth fun Al Denelsbeck Aviation Photos 4 January 11th 07 04:31 PM
