Pressure Washer
Old April 29th 05, 10:07 PM
Newps
Default Pressure Washer
Got a new pressure washer today and I want to bring it to the airport to
wash the plane. It needs 20 psi to work properly. If I put a 100
gallon water tank in my truck and fed the pressure washer with a
standard 5/8" garden hose and a 3 foot drop to the pressure washer on
the ground would that give me 20 psi?
Old April 29th 05, 10:18 PM
nrp
No - You only theoretically get about 0.43 psi per foot of water head -
and that is ignoring the wall friction effects of a 5/8 in hose.
Use auto wash soap and warm water & a rag or sponge. A pressure washer
is hell on bearing seals etc and will promote corrosion in the areas
that get pried open from the wash pressure.
A rainy day also makes a good wash day with a soft water rinse.
Old April 29th 05, 10:53 PM
Newps
So what would the pressure be?
Old April 29th 05, 11:14 PM
Dave S
Water pressure is a matter of height/elevation. From my fire department
days, you will get static pressure of 1/2" pound PSI per foot of
elevation.. so you need 10 feet of water to get that 20 psi.
You've got approx 1.5 psi there of head pressure.
Considering you will be flowing very little in the way of gallons per
minute, I wont address the flow related pressure loss in that 5/8" hose.
Chances are you will actually do just fine.. If not, then you need to
"make" a tank that can handle pressure (such as a large air compressor's
tank.. coat it for rust proofing, and put an air nipple on it and charge
it to 20 psi.. which is prolly overkill in my opinion.. people have
pressure washers in the back of trailers all the time with a feed tank
right next to it, running atmospheric pressure feeds.
Dave
Old April 30th 05, 03:26 AM
George Patterson
Wouldn't that be 40' of elevation to get 20 psi?
George Patterson
There's plenty of room for all of God's creatures. Right next to the
mashed potatoes.
Old April 30th 05, 04:14 AM
Dave S
Yes.. you are absolutely right.. and someone else earlier gave the more
exact value of 0.4 psi/ft so actually its more like 50 feet. I had the
right idea but did the wrong math the first time around.
Think about it like this.. most water towers are in the 100 ft range to
get spigot pressures of 40-50 psi. Modern practice is now to get away
from towers and stick with continuous duty pumps, but the old style
still persists.
Dave
Thanks.
George Patterson wrote:
department days, you will get static pressure of 1/2" pound PSI per
foot of elevation.. so you need 10 feet of water to get that 20 psi.
George Patterson
mashed potatoes.
Old April 30th 05, 03:55 PM
Nathan Young
On Sat, 30 Apr 2005 03:14:38 GMT, Dave S
still persists.
Really? This surprises me. Water towers offer a lot of benefits.
Water towers allow the purchase of smaller pumps, that will serve the
average water flow through the day, vs. peak rate. That saves initial
capital cost.
Water towers are sized to provide a day or so of water to the
community in the event that the pump breaks or power is interrupted.
Last, space on water towers are now leased to cellular carriers, so
the towers actually provide a revenue stream for the city.
OTOH, it probably costs a fair amount of money to build a water tower,
so the capital costs may outweight the benefits. Although for what
the cell carriers pay for leases, I'd be surprised if it didn't cover
the mortgage/bond on the water tower.
Old April 30th 05, 05:50 PM
houstondan
Nathan Young wrote:
((snip))
((snip))
american water works assn and most states still consider elevated water
best, ground tank on a hill works fine, but the costs for maintenance,
worker and community issues get pretty rough. the real issues are
firefighting with a dead electric grid and keeping the system
pressurized for health issues. sometimes, if you're clever, you can
get/stay certified with ground storage only by strapping in enough big
deisel generators to keep the pressure up.
personally, i like having lots of water towers with place names on them
as an easy and reasuring answer to the question "where the heck am i??"
although often as not the city name is covered with spray paint
announcing that sally did tommy which isn't much help unless you happen
to know sally. hence the aforementioned maintenance issue.
dan
Old April 30th 05, 01:29 AM
Mike Rapoport
"Newps" wrote in message
wash the plane. It needs 20 psi to work properly. If I put a 100 gallon
water tank in my truck and fed the pressure washer with a standard 5/8"
garden hose and a 3 foot drop to the pressure washer on the ground would
The answer is no you will not get 20psi. However, I have a 13hp Karcher
pressure washer that I bought at Costco and I have found that you don't need
much pressure to the inlet side for it to work. Try to get the largest
possible hose and fittings. You need an inlet that flows at least as much
as the pressure washer is rated for. The goal is to have enough pressure
that the pump doesn't cavitate. It doesn't take 20psi.
MU-2
Old April 30th 05, 02:25 AM
Newps
I can get a bigger hose but the inlet fitting is a standard garden hose
fitting.
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
Attn: Hydraulic experts - oil pressure relief fix? MikeremlaP Home Built 0 November 2nd 04 05:49 PM
Cabin Pressure Altitude Greg Esres Piloting 4 March 24th 04 08:35 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
