Stinson L-1 Vigilant
Old April 5th 20, 04:07 PM posted to alt.binaries.pictures.aviation
Miloch
Default Stinson L-1 Vigilant
https://en.wikipedia.org/wiki/Stinson_L-1_Vigilant
The Stinson L-1 Vigilant (company designation Model 74) was a 1940s American
light observation aircraft built by the Stinson Aircraft Company at Wayne,
Michigan (by November 1940 a division of Vultee Aircraft Corporation). The
aircraft was operated by the United States Army Air Corps as the O-49 until
1942.
The Vigilant was designed in response to a 1938 United States Army Air Corps
design competition for a two-seat light observation aircraft. When the
German-manufactured Fieseler Storch was demonstrated at the Cleveland Air Races,
the Air Corps revised its specifications in an attempt to match the performance
of the Storch. Stinson (later a division of Vultee), won the $1.5 million
contract over 11 competitors, including the Bellanca YO-50 and Ryan YO-51
Dragonfly.
The Model 74 was a single radial engined high-wing monoplane with trailing-edge
high-lift devices for low speed and high lift performance. The prototype
aircraft was built with full-span leading-edge automatic slots manufactured by
Handley Page, and slotted flaps. The Model V-74 was given the Army designation
YO-49 for evaluation, with the first flight by test pilot Al Schramm on 15 July
1940.
The aircraft was built of steel tubing and fabric, with the fuselage forward of
the wing enclosed in sheet metal. Control surfaces and the empennage were
fabric-covered stainless steel. The Lycoming power plant was hand-cranked
inertia starting, and was fitted with a Hamilton Standard constant speed
propeller. At least 12 ambulance conversions were fitted with Edo 49-4000 floats
(4,000-pound displacement) for amphibious landings and takeoffs.
The Vigilant was capable of stopping in less than its own length, and could
maintain stable flight at 31 miles per hour. Anecdotally, the Vigilant was said
to be capable of backwards flight in a strong headwind.
Role
Light Observation, Liaison
Manufacturer
Stinson Aircraft Corporation
Designer
A.P. Fontaine
First flight
15 July 1940
Introduction
1941
Primary users
Royal Air Force
Number built
324
The Stinson Vigilant was used in diverse roles such as towing training gliders,
artillery spotting, liaison, emergency rescue, transporting supplies and special
espionage flights. Another contract was later awarded for the O-49A which had a
slightly longer fuselage and other equipment changes. In April 1942 the aircraft
were redesignated the L-1 and L-1A (liaison). Up to 17 L-1 and 96 L-1A aircraft
were allocated to the British Royal Air Force under the Lend-Lease Act, with
varying numbers given for aircraft actually delivered (see Variants, below). The
RAF designated the aircraft the Vigilant Mk I and Vigilant Mk II respectively.
General Harry Crerar, Commander of the First Canadian Army in Europe during
World War II, maintained a Vigilant for his personal use.
Aircraft were modified for a variety of roles including as an ambulance
aircraft. No further production orders were placed as the aircraft was
superseded by procurement of vast numbers of both the militarized Piper J-3 Cub,
the L-4 Grasshopper (in addition to Aeronca's and Taylorcraft's similar
conversions), and Stinson's own L-5 Sentinel, itself produced in nearly 4,000
examples; were all generically classified as "puddle-jumper" aircraft.
A Vigilant was modified in 1943–1944 for experiments in boundary layer control
Specifications (L-1A)
General characteristics
Crew: 3
Length: 34 ft 3 in (10.44 m)
Wingspan: 50 ft 11 in (15.52 m)
Height: 10 ft 2in (3.10 m)
Wing area: 329 ft2 (30.6 m2)
Empty weight: 2,670 lb (1,211 kg)
Max. takeoff weight: 3,400 lb (1,542 kg)
Powerplant: 1 × Lycoming R-680-9 radial piston engine, 295 hp (220 kW)
Performance
Maximum speed: 106 knots (122 mph, 196 km/h)
Range: 243 nm (280 mi, 451 km)
Service ceiling: 12,800 ft (3,900 m)
Rate of climb: 408 ft/min (124.36 m/min)
Wing loading: 10.3 lb/ft2 (50.4 kg/m2)
Power/mass: 0.0867 hp/lb (0.143 kW/kg)
Stinson L-1 Vigilant pics 2 [6/8] - Stinson L-1 Vigilant.jpg (1/1) Miloch Aviation Photos 0 April 22nd 18 02:00 PM
Stinson L-1 Vigilant pics 2 [4/8] - Stinson L-1 Vigilant 5.jpg (1/1) Miloch Aviation Photos 0 April 22nd 18 02:00 PM
Stinson L-1 Vigilant pics 2 [1/8] - Stinson L-1 Vigilant 2.jpg (1/1) Miloch Aviation Photos 0 April 22nd 18 02:00 PM
Stinson L-1 Vigilant pics [7/8] - O-49 Vigilant at Bellows Field, Oahu, US Territory of Hawaii, 1940.jpg (1/1) Miloch Aviation Photos 0 April 22nd 18 01:59 PM
Stinson L-1 Vigilant pics [3/8] - Ex-USAAC O-49 Vigilant in the Weeks Museum at Tamiami, Florida, in 1989 wearing RAF-style markings.jpg (1/1) Miloch Aviation Photos 0 April 22nd 18 01:59 PM
