Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Products
Feedback request on Porting & Polishing
Old May 14th 05, 08:22 AM
MikePalmer
Default Feedback request on Porting & Polishing
I've been asked to do a follow on article on Porting & Polishing for The
Aviation Consumer from a user perspective, as it pertains to certified
engines. (The article I wrote in Light Planes Maintenance was from a
mechanical perspective.) Would like some user feedback, good or bad.
If you have a certified aircraft and had your cylinders Ported and Polished:
- Why did you do it?
- How much did it cost (per cylinder)?
- Did the shop flow match or use a flow bench? ("Don't know" is okay
answer.)
- Did the shop do a fancy valve grind as part of the package?
- If you flew the engine before the change, and if that's all that
changed (i.e. no higher compression pistons) can you tell any difference
in performance? Any WOW! factor?
- How did climb, top speed, cruise speed and fuel burn change?
- Any problems related to P&P? (any cylinder cracking in the head?)
- If the shop worked the valves, did you have any problems with
valves before and are you having any problems now?
- What kind of paperwork in the logbook, if any, discusses the
modification to the cylinders?
- Was it worth it? Would you do it again?
I would appreciate your input. Please respond to
mppalmer at a o l . c o m
Mike Palmer
Feedback needed on Porting & Polishing JohnSmith Owning 4 May 15th 05 02:00 AM
Force Feedback Yoke? Richard Kaplan Simulators 1 December 31st 04 02:09 PM
All feedback stick users....read this! FaxCap Simulators 13 January 1st 04 09:26 PM
Clearence available upon request Jeff Instrument Flight Rules 22 November 17th 03 07:35 PM
L.A. Times -- Request and Amendment Blueskies Home Built 0 August 11th 03 03:35 AM
