HYPOXIA
Old December 11th 20, 01:23 AM posted to rec.aviation.soaring
Waveguru
Default HYPOXIA
This is in response to the paraglider missing thread. Many pilots all over the world underestimate the effects of hypoxia and think that they are the exception to the rules. This ferry pilot certainly did.
https://www.youtube.com/watch?v=rt2T...1bj9GlVqnzogHl
You really have no idea how effected you are. That is one of the reasons it is so dangerous.
Boggs
Old December 11th 20, 02:55 AM posted to rec.aviation.soaring
AS
Default HYPOXIA
Boggs
Before I started wave-flying over the Appalachians in PA and VW, I took a high altitude chamber ride at the Wright-Patterson AFB in OH. It was a true eye-opener. After a few minutes off O2 at 25,000ft, they had us work on a task sheet with all kinds of stupid stuff on it: 81-3, -3, -3 etc. dEciPherAtextTHatWaswrITTenLiKEThis, find your way out of a maze; simple stuff, piece of cake! The supervisor on the outside called me on my head-set and asked me, how many thumbs I had: 10, of course - and why are these jack-a$$es behind that big window laughing at me?
Let me tell you, my work sheet would have been worth framing! The column of 81-3s was correct for the first few calculations, then my numbers got bigger again and even started to grow decimals! The text I deciphered was in some language - none of which I was familiar with - and I know a few of them! My way out of the maze was a straight line from the center to the exit - screw those walls! All this was done with full recollection and being convinced, that the round peg would go into that square hole, if they just had made that square a wee-bit larger!
We all got a good laugh out of looking at each other's work sheets after we were back 'on the ground'. The others in the chamber didn't fare much better than I did but the big take-away is this: if you think you are immune to hypoxia, you are full of it! Hypoxia is a silent killer; it creeps up on you and lets you make one bad decision after the other, all the while you are convinced that you got it under control - well, you don't!
O2 is cheap insurance and the MH-systems have reached an unprecedented level of accuracy and reliability.
If you have a chance to take a high altitude chamber ride, do it. I think the one at Wright Pat is no longer in operation, so if anyone knows where one is that is accessible to civilians, chime in.
Uli
'AS'
Old December 11th 20, 03:57 AM posted to rec.aviation.soaring
Gregg Ballou[_2_]
Default HYPOXIA
Boggs
Uli
'AS'
There is/was a traveling one. I believe it diluted the oxygen percentage instead of reducing pressure. You need a current medical to take a turn and last I heard basic med did not count. I doubt it is in operation during 'rona times.
Old December 11th 20, 11:36 AM posted to rec.aviation.soaring
Default HYPOXIA
Le vendredi 11 dĂ©cembre 2020 Ă* 01:23:10 UTC+1, Waveguru a Ă©critÂ*:
Many pilots all over the world underestimate the effects of hypoxia and think that they are the exception to the rules.... omissis...
Boggs
I'm really amazed that some pilots still question the consequences of hypoxia, even, and above all, the mild one. Everything has been studied and described, in particular in chapter 12 of the book “Dancing With the Wind” (on sale in the USA at Cumulus Soaring and Wings & Wheels), subject of a conference at the SSA Convention in Reno in 2018 (downloadable 1) then in an article published in Soaring USA in August 2018 written by the famous Dr. Daniel Johnson in collaboration with Patrick McLaughlin (Mountain High), Dr. Heini Schaffner and myself (downloadable here). And other dangers much more devious and undetectable in the short term seem to be confirmed, according to Dr. Linda Ravetti (USA): prolonged mild hypoxia, that which pilots undergo while spending hours around 10,000 - 13,000 ft without oxygen, would be an aggravating factor in the appearance of Alzheimer's disease. But that, you will not know until 20 years later!
Now, you can't say you didn't know that.
Take care!
1= http://topfly.free.fr/2018_OXY SSA_OSTIV.pdf
2= https://topfly-aero.com/wp-content/u...icle-proof.pdf
Old December 11th 20, 11:42 AM posted to rec.aviation.soaring
Default HYPOXIA
Hi, There is a typo in link 1.
Please read
http://topfly.free.fr/2018_OXY_SSA_OSTIV.pdf
Season greetings!
Old December 11th 20, 02:49 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default HYPOXIA
wrote on 12/11/2020 2:36 AM:
Le vendredi 11 décembre 2020 ŕ 01:23:10 UTC+1, Waveguru a écrit*:
Boggs
Take care!
For me, the advent of low cost oximeters was the wake-up call. Before then, I followed the FAA
requirements, typically turning on the oxygen at 12,000'; after I got one (20 years ago?), I
realized I need to turn the oxygen on at 10,000'. A few years ago, I noticed Cheynes-Stokes
breathing beginning above 8000', so 8000' is now when I turn it on.
Old December 11th 20, 02:54 PM posted to rec.aviation.soaring
John Godfrey
Default HYPOXIA
Boggs
Uli
'AS'
Uli, I remeber being there with you. One thing that sticks with me was the change in vision when the O2 was restored. COLORS came back.
For the low price of oximeters these days, we should all carry one an monitor our personal response to altitude.
FWIW
Old December 11th 20, 03:39 PM posted to rec.aviation.soaring
Nicholas Kennedy
Default HYPOXIA
When I Started flying Hang Gliders here in Telluride and Central Colorado and the Owens Valley I made dozens and dozens of trips up into the low 20's without O2. I also look back and found my self in the landing zone not remembering much on how I got there!
Then in the early 80's a guy by the name of Terry Reynolds put together a batch of nice Hang Gliding friendly O2 systems. Large Kevlar bottles, stainless steel flex lines, regulators. I bought one at our Hang Gliding Festival. I took off and I got up over 18 and remembered I had it; I turned it on and in a few minutes I went from a black and white world to one with color!
Blue Skys, green hills.
O2 is cheap and I'm now with Eric Grennwell. I go on 02 in my glider very low and if I'm cruising at 17+ every hour I turn it up high and do some deep breathing. Also coming into land I turn it up high for a few minutes. You wanna be sharp for the landing.
Nick
T
Old December 11th 20, 04:06 PM posted to rec.aviation.soaring
Mark Mocho
Default HYPOXIA
I started selling Nelson O2 systems in 1991 for hang gliding. Patrick McLaughlin of Mountain High asked if he could sell them also, and I told Jerry Nelson I didn't have a problem with it at all. Safety is safety, and the more sources for the equipment, the better. Mountain High eventually bought the Nelson line of regulators and flowmeters, and went on to develop and patent the Electronic Demand System (EDS) with altitude compensated pulse delivery. To me, it is the single greatest advance in oxygen delivery systems. I have used one in hang gliders and now sailplanes ever since they became available, and have been a dealer since the 90's. Now, at age 67, I set the delivery altitude at 5,000 ft. so I am on O2 even on takeoff. (Moriarty field elevation is 6,200 MSL.) As they say, "Don't leave home without it!"
Old December 11th 20, 04:16 PM posted to rec.aviation.soaring
John Sinclair[_5_]
Default HYPOXIA
Boggs
I have been through the altitude chamber a half dozen times, but I didn’t know my symptoms of long term oxygen deprivation until I got hypoxic on a long flight out in the same area the paraglider went down. I was on a 1000K flight and had turned Seregoda mine in the Owens Valley and was near my second turnpoint of Eureka, Nv. I was thermalling near18000 feet when suddenly, I was unable to maintain pitch control !!! Kinda like a PIO ....I was pulling when I should be pushing!
I had been experiencing a mild headache a mild stomachache for hours.........turned the oxygen knob up until the little ball was just dancing off the top of the flow meter and I was instantly able to regain pitch control. Ah ha moment, for me...........headache and stomachache are my hypoxia indicators!
On the ground, I found one of the little bladders in my cannula was ruptured and I had only been getting half the oxygen I needed.
My wife is on occasional oxygen now days after she lost one lobe in her left lung to cancer ..........her long term hypoxia symptoms are the same as mine........headache and stomachache!
JJ
Pilot with Hypoxia talking with ATC - this ends well son_of_flubber Soaring 8 September 10th 14 03:01 PM
Hypoxia imminent - Disclosure still holding breath! VOR-DME[_4_] Piloting 3 October 13th 11 10:47 PM
Hypoxia revisited Martin Gregorie Soaring 0 July 15th 04 09:14 PM
