Power Setting Tables - Tradeoffs
Old May 21st 05, 02:46 AM
O. Sami Saydjari
Default Power Setting Tables - Tradeoffs
I am a little confused about power setting options on my Piper Turbo
Arrow from my power setting table.
Assuming I want 75% power, at Sea Level, I can run it at:
1. 2300 RPM and 34.8 inches manifold pressure
2. 2400 RPM and 33.8 inches
3. 2500 RPM and 32.8 inches
4. 2575 RPM and 31.5 inches
How does one choose between these settings. Are they completely
equivalent? Is one setting easier on the enginer or props than another?
Of course, I could do a whole bunch of experiments, but if someone has
a good rule of thumb and a simple explanation behind it, I sure would
appreciate it.
-Sami
N2057M, Piper Turbo Arrow III
Old May 21st 05, 10:56 AM
Tauno Voipio
appreciate it.
-Sami
In principle, there are two things to balance:
- the pressure at the engine bearings, and
- the central forces at the prop
High rotational speed means more central forces at the prop.
The forces are proportional to the square of the speed. This
means that 10 % change creates roughly 20 % difference in
forces.
Slow rotational speed means more torque and more pressure
at the engine parts. For the oil film in the bearings there
is a two-fold effect: slower speed pushes less oil into the
contact surface and greater pressure squeezes more oil
out of the contact area.
For normal cruise, I select 2300 rpm and 31 inches, but that
is less than 75 %. I'd use 2400 rpm and 33 inches for 75 %
(although it would be about 31 inches in my Arrow due to
the intercooler).
HTH
Tauno Voipio
OH-PYM, Piper Turbo Arrow IV
tauno voipio (at) iki fi
Old May 23rd 05, 05:41 PM
jmk
You will find a lot of opinions on this, but generally you want to
climb at high RPM... cruise at the lowest RPM for which you can pull
the desired power. [Allowing, of course, for any limitations on your
RPM/power chart, yellow arcs, etc.] That means 2300 and 34.8 is a good
cruise setting for your turbo Arrow. Lower noise, less vibration, and
a lot less heat. [BTW, check your tachometer some time. Most of the
older ones read anywhere up to 200 RPM low.]
All the above assumes operating ROP, of course. If LOP then the power
settings are determined by fuel flow alone.
Old May 28th 05, 02:17 AM
bill hunter
What do you normally use in cross country flights? Do you ever run LOP.
I just bought a turbo arrow with a TurboPlus intercooler, and have not
figured out all the nuances yet.
email me at billhunter at yahoo dot com if you have any helpful hints.
"Tauno Voipio" wrote in message
Of course, I could do a whole bunch of experiments, but if someone has a
appreciate it.
-Sami
forces.
the intercooler).
HTH
Tauno Voipio
Old May 28th 05, 02:55 AM
Matt Barrow
"bill hunter" wrote in message
I _always_ run LOP.
GAMIjectors.
Old May 28th 05, 03:40 AM
john smith
Just remember to follow "Deakin's Rules"...
- Do not run Lean of Peak above 65% power.
Old May 28th 05, 03:50 AM
Matt Barrow
"john smith" wrote in message
For a normally aspirated engine.
Old May 28th 05, 12:21 PM
Tauno Voipio
appreciate it.
-Sami
forces.
the intercooler).
HTH
Tauno Voipio
That's what I have, with a power upgrade to 220 hp for 5 min at start.
Leisurely cruise with 28 inches (including the intercooler 3 inches)
and 2300 rpm. Fuel flow a little less than 10 gallons/hour.
Tauno Voipio
PDA GPS power issues (i.trek Mouse) Mark Morissette Owning 8 March 24th 05 03:14 PM
Power management on a O-300 Victor Piloting 0 July 9th 04 02:09 AM
Why do constant speed power setting charts limit RPM? Ben Jackson Piloting 6 April 16th 04 04:41 AM
Winch Experts wanted Ulrich Neumann Soaring 117 April 5th 04 07:52 AM
Piper Pathfinder Article john smith Piloting 24 March 14th 04 02:04 AM
