sticky valve or
Old May 22nd 05, 01:54 PM
Dick
Default sticky valve or
Old WW2 mechanic says he hears a sticky valve on my C-85 when I fire up for
first time in morning but can't describe the sound and says it lasts only as
long as a finger snap.
Wants me to add Marvel Mystery oil. I use Aeroshell 100 (50 weight) and
change it every 25 hours.
I can't detect any roughness upon initial start around 900-1000 rpm in front
of my hanger nor during the taxi a couple of minutes to a runup spot. On
throttling up to 1500 for the mag check, I notice a slight hesitation around
11-1200 rpm that goes away quickly and thought was just from the low speed
taxi.
Since I had to put a rental down about 7 years ago for a valve problem (per
the FBO), there is a little "pucker" factor regarding this conversation G.
Light Plane Maintenance book references "hand proping before first start of
day to find 'flat' cylinder". Not sure I can identify a rapid falloff in
turning resistance (books definition).
Concern doesn't seem to get to the point where the "cold cylinder" test is
applicable as doesn't last long (his finger snap).
Am I chasing nothing or what is a valid approach?
Thanks, Dick
Old May 22nd 05, 02:09 PM
Scott
Try the MARVEL!! We've been using it (dad & I) for 30 some years mixed
in with the gas but I now think I will also use some in the oil). The
first time I didn't use it (along with 100LL on a cross country trip) I
stuck a valve with my A-65. Ran Marvel after the event, but was unable
to unstick it. Decided to pull all cylinders and have the 100 Octane
valves installed. So Marvel at something like $10/gallon, or $2000 to
have the cylinders re-worked. I could buy lots of Marvel for $2000...
Scott
taxi.
Thanks, Dick
Old May 22nd 05, 03:10 PM
mixed
The
I
unable
to
$2000...
Scott
fire up for
lasts only as
and
in front
spot. On
hesitation around
low speed
taxi.
problem (per
conversation G.
start of
falloff in
test is
Thanks, Dick
I have used MMO in my vehicles and tractors and all other internal
combustion equipment for 50+ years and depend on it to help prolong the
life. Will in plane engines also.
Good luck.
Bob Olds RV-4
Charleston,Arkansas
Old May 22nd 05, 03:59 PM
Stealth Pilot
snip
Thanks, Dick
get someone else to start your aircraft and stand beside him
listening. obviously he thinks he can hear something.
probably a clack clack clack sound which quickly vanishes as the valve
frees up and goes back to tolerances with the rocker.
just a thought.
Stealth Pilot
Australia.
Old May 22nd 05, 10:34 PM
Dick
good thought. Another I heard is to pull prop thru all 4 cylinders and feel
for "flat" cylinder.
"Stealth Pilot" wrote in message
for
as
snip
Thanks, Dick
just a thought.
Stealth Pilot
Australia.
Old May 23rd 05, 02:44 AM
Scott
And if you're REALLY (un)lucky (like I was), you might hear air rushing
past a stuck exhaust valve and hear the hiss out the exhaust pipe when
pulling it through. Then you'd have it narrowed down to 2 cylinders...
Scott
for
as
snip
Thanks, Dick
just a thought.
Stealth Pilot
Australia.
Old May 23rd 05, 10:07 AM
Jan Carlsson
If following the firing order it is easy to know what cylinder it is.
But I got the feeling it can be the hydraulic lifter that is slow to fill up
after engine start, it usually make a ticking sound that quit after a few
seconds.
pull the prop slow and then fast and listen from the exhausts (or carb) and
you know where to start looking.
Jan
www.jcpropellerdesign.com
"Scott" skrev i meddelandet
Scott
feel
for
only
as
snip
Thanks, Dick
just a thought.
Stealth Pilot
Australia.
Old May 23rd 05, 08:31 PM
Robert M. Gary
I would do a wobble test. If you do have a slight stick to the valve it
will get worse and at some point could cause in flight problems. A
wobble test should set your mind at ease.
Old May 24th 05, 12:24 AM
Deborah McFarland
Dick,
The hesitation at 1100-1200 rpms in a C-85 is normal. I have it on mine (275
smh with 0-200 conversion stc) as do most of my Luscombe brethren with the
C-85.
I recently had an exhaust valve to stick in flight. It was interesting to
say the least, and in reaction to that experience I would like to pursue a
glider rating ;-).
My valve in my 275 hour ECI cylinder was stuck but good. My engine guy
reamed it out a little as he thought the clearance was a little tight. MMO
is now part of my regular maintenance routine.
Deb
1946 Luscombe 8A (His)
1948 Luscombe 8E (Hers)
1954 Cessna 195B, restoring (Ours)
Jasper, Ga. (JZP)
"Dick" wrote in message
for first time in morning but can't describe the sound and says it lasts
only as long as a finger snap.
front of my hanger nor during the taxi a couple of minutes to a runup
spot. On throttling up to 1500 for the mag check, I notice a slight
hesitation around 11-1200 rpm that goes away quickly and thought was just
from the low speed taxi.
(per the FBO), there is a little "pucker" factor regarding this
conversation G.
of day to find 'flat' cylinder". Not sure I can identify a rapid falloff
in turning resistance (books definition).
Thanks, Dick
Old May 24th 05, 12:40 AM
Deborah McFarland wrote:
Dick,
mine (275
with the
C-85.
This is fairly common on a lot of carbureted engines. It usually
occurs at the point where the carb is shifting from the idle circuit to
the main jet.
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 11:20 PM
WTB: ASW 27A water valve Peter Van Camp Soaring 0 April 28th 04 11:37 PM
Stuck valve versus plugged injector Viperdoc Owning 6 April 13th 04 01:15 AM
Dry Valve Lash jls Home Built 6 April 5th 04 07:43 PM
Q: Disecting a cut-off valve? Michael Horowitz Home Built 0 March 6th 04 02:47 PM
