NTSB Kobe
Old February 9th 21, 05:10 PM posted to rec.aviation.soaring
Default NTSB Kobe
Spatial disorientation.
No real surprises.
Wes, since you stalk my posts, pass this on to George, I think you have to be pretty stupid to fly aircraft that aren't equipped or certified into IMC on purpose.
Old February 9th 21, 05:34 PM posted to rec.aviation.soaring
Default NTSB Kobe
No real surprises.
CFIT.....VFR into ground when in IMC.....we will never know....sucks....similar across the planet every year..
Yes, I have done "stupid stuff" over the decades....that whole "old & bold" saying.....I'm still here to read, not judge.....the ground judges.....
Old February 10th 21, 11:18 PM posted to rec.aviation.soaring
John Good
Default NTSB Kobe
It was FIT, but not CFIT: the helicopter was well outside controlled flight prior to impact (steep left turn, 160 kt ground speed, 4000 fpm rate of descent).
Old February 11th 21, 05:54 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default NTSB Kobe
Got a lot of helicopter time do you? This guy screwed up. However, if you fly a helicopter you will end up scud running. But when it gets really bad, just stop and set it down. Happens to every helicopter pilot if you fly enough. By way of qualifications, I am a commercial instrument rated rotorcraft with a few thousand hours turbine helicopters.
No real surprises.
Old February 13th 21, 12:47 AM posted to rec.aviation.soaring
Nicholas Kennedy
Default NTSB Kobe
Did this Helicopter have a autopilot?
Nick
T
Old February 13th 21, 02:34 PM posted to rec.aviation.soaring
John Good
Default NTSB Kobe
Yes, according to the NTSB's Accident Investigative Update:
"The helicopter was equipped with a four-axis automatic flight control system, electronic flight instrument system, radio altimeter, and ADS-B transponder."
Old February 13th 21, 07:06 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default NTSB Kobe
S-76's are very stable helicopters even without the autopilot. So this is the aeronautical equivalent scheduling a high event at the Four Seasons Landscaping Parking Lot, across from the adult bookstore.
Screwed the pooch when they had all the resources to be successful. A poem doesn't have to rhyme to be a home run. The pilot also had the ground to land on before it got too bad or a few thousand feet climb to the clear. If you screw up this bad as as a pilot, please do it alone. A Nine year old and thirteen year old were killed before life had even begun.
Nick
T
Helicopter carrying Kobe Bryant, 41, and his daughter Gianna, 13, flew through fog despite police GROUNDING their fleet... Miloch Aviation Photos 9 January 28th 20 01:52 AM
Kobe Bryant's chopper circled for 15 minutes over Burbank waiting for landing clearance in dangerously poor visibility... - kobe crash diagram.jpg Miloch Aviation Photos 0 January 27th 20 04:57 PM
Kobe Bryant among those killed in California helicopter crash Byker Piloting 0 January 26th 20 11:14 PM
go to NTSB.GOV [email protected] Piloting 0 August 15th 05 08:34 PM
FAA-NTSB [email protected] Piloting 4 January 25th 05 01:34 PM
