Light Color Polyester Putty
Old February 16th 21, 08:08 PM posted to rec.aviation.soaring
Roy B.
Default Light Color Polyester Putty
Does anybody know a source for light colored 2-part polyester putty? The ones up here all have a bright colored hardener which helps on the mixing but shows through after a thin coat of white paint. I'd like something in a light grey or white color (after mixing) and preferably in a small quantity.
Thanks
ROY
Old February 16th 21, 08:26 PM posted to rec.aviation.soaring
Hank Nixon
On Tuesday, February 16, 2021 at 2:08:38 PM UTC-5, Roy B. wrote:
Does anybody know a source for light colored 2-part polyester putty? The ones up here all have a bright colored hardener which helps on the mixing but shows through after a thin coat of white paint. I'd like something in a light grey or white color (after mixing) and preferably in a small quantity..
Thanks
ROY
I use Evercoat polyester glazing putty and white cream hardener available from TCP Global and likely Eastwood.
Ends up more easily covered light grey.
UH
Old February 17th 21, 02:48 AM posted to rec.aviation.soaring
Thanks
ROY
UH
There is one of the best supply facilities in the country located in Ft. Pierce , Florida. Fiberglass Supply Depot, is the go to people for the boat builders located here on the Treasure Coast. They carry many different supplies for fiberglass and gel repair. They offer an online catalog, and ship all over the world. They have been my go to people for refinishing supplies.
Old February 17th 21, 03:15 AM posted to rec.aviation.soaring
AS
Thanks
ROY
Roy - try 'UPOL Dolphin One Fill UPO660'. It is a white 'All in One Premium Body Filler' (TiO2 pigmented) which comes with a white hardener paste - doesn't get more white than that. It says it won't clog sand paper and is resistant against pin-holes.
Uli
'AS'
Old February 17th 21, 05:14 AM posted to rec.aviation.soaring
Mark Fisher
If its Polyester, the red or blue harder carries a dye so you can tell how well you have mixed the stuff.
Gelcoat is polyester as well, and uses Methyl Ethyl Ketone Peroxide (MEKP) as a catylyst.
Its a clear liquid. Keep it out of your eyes!
That will also work in your Filler. Too much and goes off too fast. Experiment.
Cheers
Mark
Thanks
ROY
Uli
'AS'
HAL Light Combat Helicopter (India) pics [1/8] - 0HAL Light Combat Helicopter (LCH) attach gunship missle.jpg (2/2) Miloch Aviation Photos 0 June 7th 19 03:33 PM
Questions on UV curing polyester resins. Fred the Red Shirt Home Built 4 March 21st 10 05:07 AM
Questions on UV curing polyester resins. Fred the Red Shirt Home Built 0 March 20th 10 08:23 PM
What is best "JB Weld" type epoxy putty? [email protected] Home Built 4 March 8th 04 08:45 AM
Fairing Putty Flyhighdave Home Built 1 January 30th 04 12:54 PM
