Another way to replacing instrument panels
Old February 24th 21, 01:14 AM posted to rec.aviation.soaring
ben soaring
Default Another way to replacing instrument panels
Why bother chasing a new instrument panel? They are very expensive, hard to get, and a blank "factory" panel is difficult to cut properly and get "spot on".
This alternative method works great and actually offers "easier to service" benefits. The concept is to cut a new panel from redi-available and relatively inexpensive soft aluminum sheet then fasten the new aluminum panel to your old factory panel "skelton" by use of rivnuts. With the old panel completely stripped, "hollow" out the panel "face" creating a structural skelton to hold the new aluminum panel. It takes a bit of fiddle and fit but it comes together quickly. Leave as much lip as possible to maintain strength and hold rivnuts. Done correctly, it is hard to notice new panel is an overlay.
The best example of this was a 2 piece aluminum panel with a removable full length center section that allowed you to replace your flight computer in less than 30 minutes. The center section also mounted the transponder, switches, fuses, and USBs below the flight computer allowing complete access to the maze of all that without removing the canopy.
Beats the hell out of servicing something mounted to a factory panel.
Selling: 2 instrument panels for LS-10. Also 57mm Airspeed indicator. John Bojack J4 Soaring 4 January 17th 17 05:30 AM
Replacing innertubes without replacing tires? Ben Jackson Owning 28 November 6th 06 05:54 PM
F4 Phantom Jet vs concrete wall + McDonnell Aircraft F-4 instrument panels Hans Piloting 2 May 22nd 06 11:48 PM
F4 Phantom Jet vs concrete wall + McDonnell Aircraft F-4 instrument panels Hansi Instrument Flight Rules 0 May 22nd 06 09:44 PM
Replacing Instrument Faces? Marco Leon Owning 1 October 25th 04 07:02 PM
