New IGC Flight Recorder - Fenix FR from RC Electronics
Old April 22nd 21, 08:07 PM posted to rec.aviation.soaring
Ian Strachan[_4_]
Default New IGC Flight Recorder - Fenix FR from RC Electronics
An IGC-approval document for the Fenix FR by RC Electronics was published on 20 April:
This is the first FR from RC Electronics, based north of Celje, Slovenia
There are now 61 main types of IGC-approved Flight Recorders, and the number increases to 77 when different models within main types are added.
The main table of all IGC-approvals, individual IGC-approval documents, and DLL files for checking the integrity of IGC files for flights to be validated to IGC standards, can be downloaded from either the GFAC or FAI/IGC web sites, see below, together with other information on IGC-approved Flight Recorders.
More detail is in the notes that follow.
Ian Strachan
Chairman, IGC GNSS Flight Recorder Approval Committee (GFAC)
www.ukiws.uk/GFAC
Notes: 1. For the GFAC web site, see: www.ukiws.uk/GFAC
the complete table can be viewed directly at:
www.ukiws.uk/GFAC/igc_approved_frs.pdf
The table lists the name and main characteristics of individual IGC-approvals and in the last column there is a link to individual documents; click the link to call up the document. The table is followed by a list of individual IGC-approval documents in alphabetical order of manufacturer’s name from Aircotec to Zander. These can be called up by clicking the document name.
2. For the FAI/IGC web site go to: www.fai.org/igc-documents
Scroll down and click "Flight Recorders",
look down and click on: "IGC-approved Flight Recorders - Approval Documents"
then click on "IGC-approval Documents for all IGC-approved Flight Recorders"
This will call up a list of documents, the first one being:
"igcapproval_table_history_-_date.pdf"
followed by FR manufacturers in alphabetical order from Aircotec to Zander
If you own or fly with one of these FRs, it is recommended that you download its latest IGC-approval document from one of the web sites given above, and note any changes that may affect how you operate it.
The document with the table of IGC-approvals contains a number of other items, as listed below:
(1) A table of all types of IGC-approved Flight Recorders in alphabetical order of manufacturer name, with links to their IGC-approval documents in the right hand column under "Date of Latest Document".
(2) A table of Manufacturers of IGC-approved Flight Recorders, in alphabetical order of name.
(3) A diary of all IGC-approval activity from the first IGC-approvals in 1996 to the present day, recent events first.
(4) A history of GNSS Flight Recording in IGC together with pictures of some early Recorders.
Flight Path App flight recorder S. Vihlen Soaring 3 August 10th 12 06:48 PM
Flight Recorder for BlackBerry? C-FFKQ (42) Soaring 0 August 10th 12 05:31 PM
flyWithCE Flight Recorder John Godfrey (QT)[_2_] Soaring 4 November 13th 09 08:10 PM
New flight recorder - flyWithCE Flight Recorder uros Soaring 12 May 5th 09 09:31 PM
In flight recorder Lou Piloting 23 March 24th 07 01:45 AM
