Turbines - will Innodyn succeed?
Old June 3rd 05, 06:33 AM
Montblack
Default Turbines - will Innodyn succeed?
Saw a story on Innodyn turbines. Are their claims realistic? Will they
succeed?
188 pounds?
7 gallons per 100 hp?
Can they scale this ...DOWN?
Would a (80-100 hp) turbine weighing 100-140 pounds be a hit? Burning
5-6-7-8 gallons per hour?
Again, can their 165 hp - 255 hp turbines be scaled DOWN to a Rotax 582/912
size?
http://www.innodyn.com/aviation/faq.html
(From Products page)
Innodyn offers a number of Turbines to meet the experimental pilot's needs.
While every model is based on Innodyn's core Turbine design, each is
optimized to provide the strongest performance.
Each Turbine weighs no more than 188 pounds, and is designed for use with
our firewall forward kits. We're confident that our Turbines and firewall
forward kits are right for the vast majority of experimental applications.
Please feel free to contact us with any questions.
Our Turbines are designed for output speeds of 2,000; 2,250; 2,500; 2,750;
3,000; and 3,600 RPM. We recommend the use of 2,750 RPM for fixed-wing
aircraft applications.
Innodyn 165TE
165 Horsepower
Introductory Price: $26,500
Innodyn 185TE
185 Horsepower
Introductory Price: $28,000
Innodyn 205TE
205 Horsepower
Introductory Price: $29,500
Innodyn 255TE
255 Horsepower
Introductory Price: $34,500
Montblack
Old June 3rd 05, 07:40 AM
Sparkle
succeed?
188 pounds?
They'll all weigh the same, regardless of power output.
Innodyn took the initiative in inventing 188 pound turbines.
Old June 6th 05, 05:19 AM
Rich S.
"Sparkle" wrote in message
The Boeing Model 502 - in the 1950's - weighed 140 lbs. and put out 200 hp.
Oh, wait - you said 188 pounds. I stand corrected. Why would they want such
a heavy engine?
Gawsh, technology has sure come a long way in fifty years.
Rich S.
P.S. The Boeing Model 500 Turbo-jet weighed 85 pounds, developed 150 pounds
of thrust, and was 29" long, 22" in diameter. The extra 55 pounds of the 502
was the gear reduction.
Old June 6th 05, 06:08 AM
Anthony W
a heavy engine?
Rich S.
Why aren't more old Boeing engines finding their way into homebuilts? A
140 bound 200HP engine sounds sweet. With a couple of those I could get
serious about my dreams to build an ME262... ;o)
Tony
Old June 6th 05, 08:55 AM
I was trying to figure out the fuel burn on the AMT ( jet models )
engines. As close as I could figure, they burn about 4 gph. And the
thrust was listed in KG and there were other variables related to this
thrust ( air temp, etc. ) but a guy put 2 of them ( poor mans dual
ignition )on his Cri-Cri aircraft and flew at 150 mph. I think they
said he had 35 KG of thrust. Of course, the engines only weigh 5 lbs.
each which is pretty cool.
Neal
Richard Riley wrote:
On Thu, 2 Jun 2005 23:33:10 -0500, "Montblack"
:Saw a story on Innodyn turbines. Are their claims realistic? Will they
:succeed?
:188 pounds?
Entirely possible.
:7 gallons per 100 hp?
Not without violating the laws of physics. Their compression ratio
isn't nearly high enough.
::Can they scale this ...DOWN?
Sure
:Would a (80-100 hp) turbine weighing 100-140 pounds be a hit?
Well, that's kind of what it was derived from - the Solar T62-2A 95 hp
from 50 lb weight.
:Burning
:5-6-7-8 gallons per hour?
Not a chance. The smaller a turbine, the more fuel it will burn for
the HP (it's really more complex than that, but that's a good rule of
thumb). You could easily get a turbine to burn 5 GPH - while
producing about 20-25 HP.
:Again, can their 165 hp - 255 hp turbines be scaled DOWN to a Rotax 582/912
:size?
Sure. As long as you aren't worried about fuel burn.
:http://www.innodyn.com/aviation/faq.html
From Products page)
:Innodyn offers a number of Turbines to meet the experimental pilot's needs.
:While every model is based on Innodyn's core Turbine design, each is
:Each Turbine weighs no more than 188 pounds, and is designed for use with
:forward kits are right for the vast majority of experimental applications.
:Please feel free to contact us with any questions.
:Our Turbines are designed for output speeds of 2,000; 2,250; 2,500; 2,750;
:3,000; and 3,600 RPM. We recommend the use of 2,750 RPM for fixed-wing
:aircraft applications.
Before you invest a moment more of your time or a cent more of your
money, ask two questions:
1) Have they ever delivered one of their engines to anyone, anywhere?
2) If you were to build a homebult with a turbine engine could you get
it insured by any aviation underwriter currently in business?
Hint - the answer to the second question is not "yes".
Old June 6th 05, 06:56 PM
Montblack
wrote)
IIRC, LBS thrust = ("roughly" ...be gentle) 65% for its horsepower
equivilant.
100 lbs thrust will be about 65 hp. Is this close to being a workable rule
of thumb?
http://www.amtjets.com/gallery_real_plain.html
(I want one!!!)
http://www.flight.cz/cricri/english/index.php
(more Cri-Cri pics)
Montblack
Old June 6th 05, 10:03 PM
UltraJohn
M IIRC, LBS thrust = ("roughly" ...be gentle) 65% for its horsepower
equivilant.
of thumb?
Montblack
I understand it is speed dependent. At standstill it is 100 lbs = 0 HP and
at 600+ mph it is close to 100lb = 100 HP. I'm no expert so be gentle on me
too! ;-)
John
Old June 6th 05, 10:11 PM
Marc J. Zeitlin
equivilant.
rule of thumb?
Nope.
Power = Force x Velocity
For a "thrust" engine, the equivalent "power" it's producing will be
dependent upon how fast it's going. At 60 MPH, 100 LB of thrust is
equivalent to about 16 HP. At 150 HP, 100 LB of thrust is about 40 HP,
so you can see that a rule such as you postulate isn't going to work.
Marc J. Zeitlin
http://marc.zeitlin.home.comcast.net/
http://www.cozybuilders.org/
Copyright (c) 2005
Old June 7th 05, 12:00 AM
Matt Whiting
Burning 5-6-7-8 gallons per hour?
200 hp.
such a heavy engine?
Rich S.
pounds of thrust, and was 29" long, 22" in diameter. The extra 55
pounds of the 502 was the gear reduction.
Tony
I'm not sure, but I'll venture a guess ... fuel consumption is probably
outrageous.
Matt
Old June 7th 05, 12:26 AM
Anthony W
A 140 bound 200HP engine sounds sweet. With a couple of those I could
get serious about my dreams to build an ME262... ;o)
Tony
outrageous.
Matt
Either that or they cost a fortune to maintain.
Tony
Solar Turbines [email protected] Rotorcraft 2 January 16th 05 02:30 PM
Innodyn turbines Paul Folbrecht Home Built 12 July 6th 04 08:36 PM
Plasma Reduces Jet Noise (Turbines?) sanman Rotorcraft 1 June 27th 04 01:45 AM
Getting rid of turbines. (grin) ArtKramr Military Aviation 15 December 6th 03 06:25 AM
Wind Turbines and stealth Arved Sandstrom Military Aviation 6 August 8th 03 11:30 AM
