Hi All!
OK... Piper Warrior...PA28-151 Considering purchase... It's is a 1976 Model.. Specs, (published) say stall, dirty ( Full Flaps ) for a 1976 built is 58 knts. ....1977 and later is 44 knts! WHAT changes were made to bring the stall speed down by 14 knts! I have looked at both, I cannot (untrained eye) see what is different.. Owner of the '76 says 52 knts(w/flaps) , 58 knts "clean" (????) Tis a huge difference... is this correct? Why? Can the 76 be modified to get the stall speed lower? Can any one help here? What is the story? Thanks in advance! Dave |
On 3-Jun-2005, Dave wrote: Specs, (published) say stall, dirty ( Full Flaps ) for a 1976 built is 58 knts. ...1977 and later is 44 knts! Both of these numbers sound VERY bogus. According to specs from the Plane & Pilot website, a 1981 Warrior II has a full-flaps stall speed of 50 kts. This is in line with the gear down, full-flaps stall speed of 53 kts for my Arrow IV which has the same wing but is a bit heavier. 44 kts is the stall speed for a C-172 with full flaps, and no PA-28 model will come close to that. 58 kts is only 3 kts below the maximum "dirty" configuration stall speed generally allowed by the FAA for certificated single engine airplanes. I would expect something like an A-36 Bonanza or a Piper Mirage to have a "dirty" stall speed in this range, certainly not a Warrior. I'll bet that Warriors of all vintages have pretty much the same flaps-down stall speed, and 50 kts sounds about right for that speed. -- -Elliott Drucker |
The numbers are correct, according to the POH. The units are off,
though (as pointed out by another post). Its 58 MPH for the 151, and 44 KTS for the 161. The numbers are in line with what I have experienced with the 161. Don't know what was changed between 151 and 161 though... I know wings were changed at some point in the warrior line, but I think that was before 1976. |
"Dave" wrote in message ... Hi All! OK... Piper Warrior...PA28-151 Considering purchase... It's is a 1976 Model.. Specs, (published) say stall, dirty ( Full Flaps ) for a 1976 built is 58 knts. ...1977 and later is 44 knts! WHAT changes were made to bring the stall speed down by 14 knts! Are you sure the units are the same? Older birds used MPH. Vaughn |
Considering purchase... It's is a 1976 Model.. Specs, (published) say stall, dirty ( Full Flaps ) for a 1976 built is 58 knts. ...1977 and later is 44 knts! WHAT changes were made to bring the stall speed down by 14 knts! Are you sure the units are the same? Older birds used MPH. Vaughn I'll bet Vaughn is right on this one. My '63 Cherokee 180 POH is all MPG instead of KPH. I thought that most companies had switched totally to KPH by about 1970, but I recently checked out in a '76 Arrow and the POH on it was also full of MPG instead of KPH. Check with that owner to see if he was quoting knots or statute MPH. Because those numbers do sound high. My Cherokee 180 POH quotes 57 as the "Stalling Speed (flaps down, MPH). 57MPG is just under 50 KPH -- about 49 knots. That would be a little more reasonable for a Warrior, which is very similar in design to a Cherokee. Oh, and remember -- there are things that can be done to modify those stall speed numbers. Putting on newer design "Horner" style wing tips and stabilator tips will drop stall speed about three to five MPH. Vortex generators on the wing top just behind the leading edge can drop stall another MPH or two. Flap & aileron seals can make a difference. Fairings on the flap extension actuators help. Wing root seals/fairings help. Wheel pants are a BIG help. Etc... From my reading, you can actually get your stall speed down almost 10MPH by putting on every gizmo kit STC'ed for a Warrior. And at the same time, you'll be adding top end speed to the plane as you smooth out the airflow. Problem is -- you'll spend a fortune doing it !!! Chuck |
Chuck wrote:
: I'll bet Vaughn is right on this one. My '63 Cherokee 180 POH is all : MPG instead of KPH. I thought that most companies had switched : totally to KPH by about 1970, but I recently checked out in a '76 : Arrow and the POH on it was also full of MPG instead of KPH. OK... I can't take it anymore. Unless I missed a meeting, the following are common abbreviations: MPH: Miles per hour. Generally assumed statute miles KPH: Kilometers per hour. Generally not used in aviation AFAIK MPG: Miles per gallon. Generally assumed to be statute miles. KT: Knots. A.K.A Nautical miles per hour The confusion of the OP is about units, so being sloppy in the explanation doesn't help and adds to my confusion (which I didn't even know I had). : Oh, and remember -- there are things that can be done to modify those : stall speed numbers. Putting on newer design "Horner" style wing tips : and stabilator tips will drop stall speed about three to five MPH. : Vortex generators on the wing top just behind the leading edge can : drop stall another MPH or two. Flap & aileron seals can make a : difference. Fairings on the flap extension actuators help. Wing root : seals/fairings help. Wheel pants are a BIG help. Etc... : From my reading, you can actually get your stall speed down almost : 10MPH by putting on every gizmo kit STC'ed for a Warrior. And at the : same time, you'll be adding top end speed to the plane as you smooth : out the airflow. Problem is -- you'll spend a fortune doing it !!! For the record, the Art Mattison VG's on the Hershey-bar Cherokees does a really good job of reducing the stall speed. My -180 used to be barely flyable at 60 mph IAS will full flaps. With the VG's (and light-medium loaded), it'll *fly* at 60mph no flaps. Hang it on the prop with full flaps and it doesn't stall until 45mph. The wingtips help reduce the (already bad) sink of the PA-28's at slow airspeeds, so it helps climb a bit. The wheel pants give a bit of speed.... 2-3mph on the old style, 3-5 on the new. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
On 6-Jun-2005, Chuck wrote: I'll bet Vaughn is right on this one. My '63 Cherokee 180 POH is all MPG instead of KPH. I thought that most companies had switched totally to KPH by about 1970, but I recently checked out in a '76 Arrow and the POH on it was also full of MPG instead of KPH. I think you mean MPH (miles per hour) and kts (knots), not MPG (miles per gallon?) and KPH (kilometers per hour). Oh, and remember -- there are things that can be done to modify those stall speed numbers. Putting on newer design "Horner" style wing tips and stabilator tips will drop stall speed about three to five MPH. Vortex generators on the wing top just behind the leading edge can drop stall another MPH or two. Flap & aileron seals can make a difference. Fairings on the flap extension actuators help. Wing root seals/fairings help. Wheel pants are a BIG help. Etc... In order to lower stall speed for a given weight, all else being equal, you need to change the wing's lift coefficient at stalling speed. Thus different wing tips may help lower stall speed a tiny bit. Vortex generators may help more. Mods that provide drag reduction (fairings, wheel pants, etc.) should have NO effect on stall speed. Changing the lift coefficient of the horiz. stab. will likewise have NO effect because it does not stall before the wing (except in canard designs). From my reading, you can actually get your stall speed down almost 10MPH by putting on every gizmo kit STC'ed for a Warrior. And at the same time, you'll be adding top end speed to the plane as you smooth out the airflow. Problem is -- you'll spend a fortune doing it !!! That is, if you believe all the hype from the people trying to sell these mods. -- -Elliott Drucker |
Dave wrote: It's is a 1976 Model.. Specs, (published) say stall, dirty ( Full Flaps ) for a 1976 built is 58 knts. ...1977 and later is 44 knts! power on stall? or power off stall? Wouldn't the 150hp vs 160hp make a difference? -- Bob Noel no one likes an educated mule |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Reading back altimeter settings? | Paul Tomblin | Piloting | 31 | April 12th 05 05:53 PM |
| Bush Pilots Fly-In. South Africa. | Bush Air | Home Built | 0 | May 25th 04 07:18 AM |
| DCPilots for Washington, DC area pilots | Bill | Piloting | 0 | May 16th 04 03:28 AM |
| Piper doors, why the passenger side? | Nathan Young | Owning | 58 | September 29th 03 02:38 AM |
