Missing Engine Log Book
Old June 7th 05, 11:02 PM
Default Missing Engine Log Book
Hello Guys:
I am in the process buying a malibu and I was just told the engine log
is missing (overhauled in 1996, currently 850 hours smoh)but the owner
has MOST of the invoices for the work done during last nine years since
the overhaul. My questions are the following;
1. How much is the discounted value on this airplane without the engine
log?
2. Can a replacement log book be generated with these invoices? if so,
would it be just a record or a log book that is as good as the orginal?
3. To what extent will the reconstructed log book to be considered a
good one. For example: If the seller has the original invoice for the
overhaul work performed with total time recorded and if a paid receipt
for every annual inspection as attached. will this be acceptable?
Thank you in advance for any input.
Jack
Old June 8th 05, 05:43 AM
Matt Barrow
Hello Guys:
log?
No, and it's doubtful that the invoice has even close to the level of detail
the logs had.
good one.
Not much.
It may be legal, but again, think of how much detail is on an invoice.
Be VERY careful and discount the information DEEPLY.
Old June 8th 05, 01:33 PM
Denny
The engine is worth it's core value only - the log book is what makes
an engine CERTIFIED... Call TCM and ask them what it will cost to get
the engine certified again - and hold on to your wallet...
denny
Old June 8th 05, 04:32 PM
jmk
I'm going to disagree with Denny and say it's not nearly that bad. The
engine is certified if it has the appropriate data plate (seemingly
without regard to what is attached to the data plate G). However, if
indeed there are NO logs, then at this precise moment the engine (and
hence the aircraft) are not airworthy.
Basically all you are going to need to make it airworthy is a sheet of
paper from the AI that did the last annual, with the annual engine
signoff. That done, and without evidence of anything to the contrary,
you are legal to fly. [And don't say that because there is no log book
that you don't know if anything was done since annual to make it
unairworthy. Those are independent events, and the logbook is only one
slight way you might discover such a change.]
Now... the money items: Without proper logbook documentation, it is
harder to sell the plane. Not a big problem if you plan to keep the
plane a long time (by which time you will have probably gone through an
overhaul anyway), but still an issue.
Second, you have no record of exactly what is installed in the engine.
The last annual AI will be attesting to all the AD's performed as of
that time, but you have no formal record that they were properly
carried out. Future AI *could* (and very likely might) insist that
some work be done to verify the AD's before signing off on the next
annual. And you might find yourself doing extensive work (splitting
the case) just to find that your engine didn't even fall under some AD
in the future.
Can you make a NEW logbook? Sure, done all the time. You start by
trying to get copies of the last overhaul records, plus whatever the
manufacturer might still have on that specific serial number. Ditto
the accessories. Then take all the receipts, invoices, etc. And you
make up what you can. Perfectly legal... but doesn't really solve all
the problems above.
Me? I would start with the negotiating position that the engine is due
for overhaul and reduce the price as if the engine was at TBO.
Old June 8th 05, 06:41 PM
RST Engineering
As others have pointed out (and I won't belabor their points) this is not
true.
"Denny" wrote in message
Old June 8th 05, 08:53 PM
Denny
Well, simple enough to find out for sure... He can call the FSDO and
ask them if he makes up a logbook is the engine airworthy... Be
interesting for him to report back to us... I'm always willing to
learn...
denny
Old June 8th 05, 09:17 PM
Robert M. Gary
Is this really true? You can certify the time on the engine simply by
using the shop records from last annual and adding the time since. You
will probably have to have any ADs resigned, but other than that, I
can't think why you can't recreate the log book.
-Robert
Old June 8th 05, 10:23 PM
learn...
There's really no requirement to have a logbook for the engine at
all. There are record keeping requirements, but they don't specify you
have to have everything in some type of book.
That said, to be airworthy, all of the ADs on the engine have to be
signed off somewhere. While reciepts with hours and details of work
might be informative, unless they are properly signed off (unlikely),
that doesn't satisfy the requirements. I would think that you'd have
to get the proper signoffs before the engine was airworthy. This might
be a simple as having the original signer recreate the entries in a new
logbook, or as difficult as having all applicable ADs performed again.
Old June 8th 05, 10:39 PM
Doug
There is no set amount here. I have heard 25% off total price for
missing logs (totally missing). There is something in the FARS about
re-creating lost logs. That is what I would do if I owned the plane.
Just create a log for each invoice or something similar. Sign it off as
"recreated log". Better than nothing. I guess I'd argue for 25% of the
value remaining on the engine until TBO? So if the engine is 50% to
TBO, and a zero time is 40k, then 5k off. (25% of 20k)?
Old June 8th 05, 11:47 PM
Javier Henderson
"Denny" writes:
learn...
Why do you think "the logbook" is needed?
Can you point out where the FARs speak of "logbook"?
What are the FAR stated requirements for this "logbook"?
How long must one keep this "logbook"?
-jav
Missing engine Marty Schmidt Piloting 3 October 27th 04 10:03 PM
Engines and Reliability Dylan Smith Piloting 13 June 30th 04 04:27 PM
My Engine Fire!! [email protected] Piloting 21 April 2nd 04 06:02 PM
Engine... Overhaul? / Replace? advice please text news Owning 11 February 17th 04 05:44 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 04:03 PM
